Old 08-26-2011, 01:26 PM   #1
milkwasabadidea
Default white tip spark plugs... normal?
Ok so I decided to check my spark plugs... and the tip where you gap it is grayish/white.... according to my search. That means I'm running lean.....and its grayish/white. on all spark plugs..... the thing is I have a 1998 hx swap d16y5... and its a lean burn motor.. and its swapped in legit running the correct ecu......... since I'm running this lean burn motor.. does that mean that its normal for my spark plugs to show grayish/white.?
a little more info the threads have a black stuff on it... but its not on the tip of the spark plug.. its just on the threads....... o yea i took pictures after i cleaned them so you may not see it clearly
UPDATE.... 2 plugs have very little oil on the washer portion of the plugs... JUST THE WASHER has oil on it
WTB: primary O2 sensor 96-00 civic hx *used*
milkwasabadidea is offline   Reply With Quote
Old 08-26-2011, 02:24 PM   #2
motegicivic
Default Re: white tip spark plugs... normal?
Light tan or grey is normal, your look black, either carbon.
http://www.gnttype.org/techarea/engine/plugs.html
motegicivic is offline   Reply With Quote
Old 08-26-2011, 02:42 PM   #3
grumblemarc
The Grumpiest
1996 Honda Civic
grumblemarc's Avatar
iTrader Rating: (4)
Send a message via AIM to grumblemarc Send a message via Yahoo to grumblemarc Send a message via Skype™ to grumblemarc
Where do you see white?
FAQs!--How to Turbocharge your Civic--Want a faster Civic?--DIYs
Originally Posted by wantboost View Post
I wish more parents would beat their children, then maybe most of them wouldn't be total spoiled, self absorbed *********.
grumblemarc is offline   Reply With Quote
Old 08-26-2011, 03:00 PM   #4
milkwasabadidea
The part where you gap it looks gray white.. then its black at the threads
Old 08-26-2011, 03:05 PM   #5
milkwasabadidea
Its white on the tip where u gap it.. but its black near the threads... I sea foamed the motor not too long ago... but jus through the gas tank
Old 08-26-2011, 03:08 PM   #6
milkwasabadidea
The second picture shows a little white on the tip where u gap. But the threads and circle part is black. So I have no clue what going on... I'm changing it soon though after I sea foam it
Old 08-26-2011, 03:15 PM   #7
milkwasabadidea
Jus went on ngk website. Looking at the chart, my spark plugs seems to be normal apparently... .. mayb slightly running rich..
Old 08-26-2011, 03:20 PM   #8
mathewb20
Your spark plugs are perfectly normal, white means its running lean and is not good.
mathewb20 is offline   Reply With Quote
Old 08-26-2011, 03:47 PM   #9
milkwasabadidea
it was white/gray before i cleaned them... so they look a little better....
im running a lean burn y5 motor.... isnt it supposed to show lean since its a lean burn motor?
Old 08-29-2011, 05:10 PM   #10
milkwasabadidea
update... i have very little oil on the spark plug WASHER and washer alone... nothing else
Old 08-29-2011, 06:39 PM   #11
grumblemarc
The Grumpiest
1996 Honda Civic
iTrader Rating: (4)
Running lean and a lean burn motor are not the same things. Your plugs are fine. Move on.
Old 08-29-2011, 08:08 PM   #12
98civdx
Master Detailer
98civdx's Avatar
They look okay to me, now that you have them out, might as well replace them. They don't cost more then a few bucks.
RIP Michael Young. 3-26-1991 9-2-2013
98civdx is offline   Reply With Quote
accord, black, civic, gray, honda, ip, plug, plugs, spark, sparkplugtipiswhitehonda, tech, things, tip, tips, white
