| Welcome to Honda-Tech! | ||
#1 |
1994 Honda Civic |
I am having problems with my 94 civic cx the fuel pump is not working and I'm not getting any spark it will turn over fine I have already replaced the main relay and have also put in a new ecu thought it was just a fuel problem but checked for spark today and had none is this a bad ground somewhere maybe? Any input will help
#2 |
Moderator
2000 Honda CivicMy Garage |
Check the G101 ground on the thermostat housing, 15A hood fuse 31, and 15A dash fuse 24.
Don't guess, troubleshoot --------------------------------------------------------- Useful tech links: FAQs; Codes; Check Spark; Test Fuses; Fuse 15 TSB; Clean IACV or FITV --------------------------------------------------------- Please don't PM me tech questions. Create a thread. |
#3 |
1994 Honda Civic |
Already have and nothing even cleaned the ground on the thermostat and made sure ithad a good connection still nothing
#4 |
Moderator
How did you test fuses 31 and 24?
#5 |
1994 Honda Civic |
I haven't tested them but the fuses were good even replaced with new and nothing. I will test them tommorrowto see if they have power going to them
#6 | |
Moderator
When you turn the key from off to ON(II), does the CEL turn on and then off after 2 seconds? Or does it stay on steady?
#7 |
1994 Honda Civic |
Steady it stays on the whole time
#8 |
Moderator
This is called CEL code 0 and, in conjunction with a no-start problem, generally indicates that the ECU is not getting either voltage or ground.
#9 |
1994 Honda Civic |
That is what I thought but wasn't completely sure I will test the fuses to see if I'm getting anything if they are not how do I fix it?
#10 |
Moderator
It's more productive to identify the problem before discussing the fix.
#11 |
1994 Honda Civic |
I will post the results tommorrow butim almost positive that it will not have any power cause I've eleminated almost everything else it could be
#12 | |
Moderator
If the one of the fuses does not get voltage, then (5) there's probably a bad wire between the ignition switch or hood fuse box and the fuse. Obviously, some methodical electrical testing is needed to precisely pinpoint the problem.
#13 |
1994 Honda Civic |
Ok so I tested #31 under the hood it has power but I can't find #24 under the dash it only goes to23
#14 |
Moderator
You'll find the dash fuse box diagram in the Electrical section of the FAQs sticky.
#15 |
1996 Honda Civic |
Dizzy
#16 |
1996 Honda Civic |
Scratch that only read title
| Tags |
| 1994, 24, 94, check, civic, cx, fuel, fuse, ground, honda, location, locations, pump, spark, troubleshoot |
