D Series - where do i hook a chain to pull the motor out?
Old 08-22-2011, 02:03 PM
Bipolarcivic's Avatar
Icon2 D Series - where do i hook a chain to pull the motor out?
I'm swapping my D15 for a D16. My problem is where do i hook a chain to pull the motor out? There is no plates where your supposed to hook to ?
Old 08-22-2011, 02:15 PM
hafast's Avatar
Default Re: D Series - where do i hook a chain to pull the motor out?
You can always thread a bolt into somthing and attach the chain, I did on the side of the motor and one on the thermo housing it worked fine. Every situation is different.
Old 08-22-2011, 02:18 PM
ogarcEM1's Avatar
Bolts, such as the ones that garb the transmission and motor, just make sure they are threaded enough that they can handle the motor.
Old 08-22-2011, 02:27 PM
sk8kingda3rd's Avatar
I used the top bolt on the power steering pump bracket and one of the tranny mount bolts. Worked like a dream.
Old 08-22-2011, 02:28 PM
Stonecoldn69's Avatar
It may have been bad but it worked, I threaded a bolt into the side of the head behind the alternator and used the bracket on the trans that holds the hose for the slave cylinder (slave cylinder was not attached at the time)
Old 08-22-2011, 03:39 PM
ok, i did not know if the threads would hold the weight of the motor being aluminum motor and all but thanks everyone!
Old 08-22-2011, 07:12 PM
strategy400's Avatar
I usually hook a chain up at 3 points, the top PS pump bracket bolt, then a bolt on the opposite side of the head next to the intake mani (I think I thread one of the frame-to-front-bumpstop-mount bolts in there). Then depending on if you're hoisting the engine only or engine + trans:
Engine only - One of the lower distributor bolt holes with a distributor bolt.
Or:
Engine + trans - There's a steel bracket on top of the trans.
BTW I recommend leaving that rear trans mount on the chassis and loosening the 3 bolts from the engine/trans.
Old 08-23-2011, 04:26 PM
RomeroVIP's Avatar
ive done the same
PYITR01
09-17-2011 09:35 AM
totsie7944
02-05-2008 10:05 PM
743power
01-01-2005 05:27 PM
drwatson
08-09-2004 04:09 PM
Synergy001
16
12-30-2003 03:40 PM
Quick Reply: D Series - where do i hook a chain to pull the motor out?
