how to stop polyurethane bushings from squeaking?!
Old 10-03-2002, 02:03 PM
sutrusu's Avatar
Default how to stop polyurethane bushings from squeaking?!
someone said white lithium grease spray? any other suggestions? i hate that damn squeaking when i go up/down a driveway!
Old 10-03-2002, 02:13 PM
ILUVTEC's Avatar
Default Re: how to stop polyurethane bushings from squeaking?! (sutrusu)
If the grease doesnt help, then try to wrap the hardware that the bushing goes over/in with teflon tape(Example: If this was a rear sway bar bushing then just wrap the bar first with teflon tape, then install the bushing&collar). Only down side is that this requires re-installing them, so it can be time-consuming depending on what bushing this is. Enjoy
Old 10-03-2002, 02:14 PM
Redtail's Avatar
They come with the extra thick grease from the factory, maybe you can just buy a tube of that ****. Probably just put on as much as possble and re-lube all the bushings every 6 months or so.
cheers
Old 10-03-2002, 02:18 PM
Fuuma0083's Avatar
Grease it up like a pot belly pig. Grease, Grease, Grease.
Old 11-04-2003, 05:42 PM
IntEGNYC's Avatar
Default Re: how to stop polyurethane bushings from squeaking?! (Fuuma0083)
no ky jelly
lithium grease shoudl do the trick
boxedfox
Suspension & Brakes
04-22-2018 10:35 AM
CALC!_JUST_du_IT!
Suspension & Brakes
08-28-2007 12:27 PM
fanatic
07-23-2004 01:33 PM
ragejed
09-25-2002 04:40 PM
BSQ
03-28-2002 07:09 PM
Quick Reply: how to stop polyurethane bushings from squeaking?!
