how do i adjust steering wheel?
Old 08-17-2011, 05:58 PM
TOO MUCH TORQUE's Avatar
Default asdfasd
adsjfasf
Old 08-17-2011, 06:01 PM
kaiba's Avatar
Default Re: how do i adjust steering wheel?
Toe adjustment. Get an alignment it will make things easier. Should cost no more then $40.
Old 08-17-2011, 06:32 PM
asdfasd
Old 08-21-2011, 09:29 AM
boostedteg69's Avatar
there is a plastic cover under the dash that covers the steering linkage and all you have to do is remove that and there is a nuckle where the wheel part meets the pinion and its two 12mm bolts. make sure the wheels are straight forward and then unscrew those 2 bolts and just turn the wheel till its straight and put the nuckle back on and put it all back together
SuicideSlide
19
09-30-2004 03:50 PM
neEven
03-23-2004 11:55 AM
killa_lude
01-26-2004 07:04 PM
kikkoboyie
09-15-2002 02:55 AM
Quick Reply: how do i adjust steering wheel?
