my bumper setup
#78
Re: my bumper setup
"no boost" has a hood latch still. So he will use the minis its just a fiber glass hood so they will help hold it down and stop the flex.
#83
Re: my bumper setup
Hey aHobbs
I want to delete my lower radiator support like yours can you let me know who did yours? And i really want to buy it as a kit and i can weld it on, do they do that? Thanks a ton for the info
#85
Re: my bumper setup
[QUOTE=ahobbs;46673118]Turboelements did it. (Ihaveturbos). I'd pm him or go to his site.
All around good guy (Tim@TurboElement) to do business with hands down! Quick response and will take the time for customer service. Getting mine done as well. Thanks again for the heads up Ahobbs.
#87
Re: my bumper setup
did anyone recieve the email from quick latch stating without a hood latch that you should be using 8 to 10 minis on your hood?
wondering if there just covering there *** or if that many is really necessary?
i have four of them, but to have double that would just be a mess of pins
#88
Re: my bumper setup
#89
Re: my bumper setup
thats kind of what i was thinking, adding two more latches, then making something to resemble the stock hood latch that would catch maybe a half inch up or so if the latches were to give that way once the latches are pushed as well it could move up a hair for me to fit my fat fingers in there to disengage it
#90
Re: my bumper setup
Why not just get the actual hood latches made by Quik-Latch? IMO, it's not worth it to take the chance in using the standard Quik-Latch on your hood with the possibility of it failing.
#91
HELLO,GOOD MORNIN'
Re: my bumper setup
IMO 8-10 is a bit overkill, but its more to CYA. simply put the more the better if your going to use mini's. It would become more of a Pain to latch them all. The min you unlatch one another will grab it and latch back in. Much easier with the hood pins. Like i said before. these are mainly used for bumpers and side skirts. The hood pins are made specifically for the hood.
#92
Re: my bumper setup
well i personally cant justify spending 500 dollars to latch my hood (without the actual hood latch) i didnt realise it but earlier i said i had 4 i meant that i currently have 2.
those are installed now I'm having issues trying to decide what to do get another two and a safety latch or say screw it and do two actual ugly hood pins out towards the sides and keep the two minis in the middle.
ugh decisions decisions
#93
HELLO,GOOD MORNIN'
Re: my bumper setup
its only 250 for a pair lol. Just take out the mini's and install hood pins and use the mini's somewhere else. The aerocatch are cool peices but a PITA to install. 80.00 for plastic material and 2hrs of installation. That's a choice you have to decide. I had a set of aerocatches and before i started cutting i compared the two and it took me 10min if that to install the latches lol. Time is hard to come by for me, so i try my hardest not to waste it
