CLICK HERE all of you curious about suspension setups and their costs/reliability.
#601
#1 Super Guy
Re: CLICK HERE all of you curious about suspension setups and their costs/reliability
Koni's would be overkill for OEM soft springs. While you "can" adjust the damping-rebound-rate way down to work with your soft OEM springs, it wouldn't make much sense to pay so much for dampers that require such a soft setting. That is unless you are bound by a racing rulebook. If you are going to run stock springs, use a stock style damper (KYB Excel-G are good an inexpensive).
#602
You are definitely the grumpiest but brutal honestly is the best way to learn anything in a hurry. You have the strangest way of being incredibly helpful. So i am looking for struts with an adjustable dampening rate to match whatever spring end up on the car at whatever time.
#603
The Grumpiest
Just save yourself the hassle of trying to match up shocks and springs. Go with a combo that is already proven with rates you can pick. Koni/GC with 350/250 or 350/350 or even 450/350 rates. Higher rates the lower you go. Lower rate in back for "comfort". Personally I went with Progress CS2 with 350/250 rates and added a rear 22mm? (can't remember) swaybar with a 1.5" drop.
#604
Still really appreciate the info though, i know you have noobs like myself hastleing you for info on a daily basis.
#605
The Grumpiest
That is an ADJUSTABLE setup. Meaning you can adjust it to any height you want to. Including stock height.
#606
I have the GC ones, and preloading the front springs about as much as I can by hand, the car is still 1" lower than stock.
Without them, I could go higher than stock.
Del Sol, Integra, same suspension, so the height range should be similar.
And Nave43, ditch the H brace. That's doing nothing but killing your ground clearance. It also has nothing to do with "bottoming out". If you don't want to bottom out, run an adequate spring rate for your desired ride height.
#608
One last thing, since the coil overs are adjustable should i pick rates for the height i will use them most often? Would that make the adjustable part more or less worthless? If you read what i posted about the other thread... my bad.
#609
This is my ride...98 Integra
I found a set of GC coils in my garage that I purchased for my 93 Civic a while back. I thought they were just springs, but it came with threaded collars and adjustable (up/down) ring.
I checked GC's website and they are 340 front/ 250 rear. Looking at the ride height in the 1st pic, would these spring rates be suitable for the height I'm at now? I was considering purchasing a set of Koni Yellows or Tokico Illuminas to go with these. Here are a couple of more pics showing how much of a gap I have in the front and rear wheel wells and tires.
I have about a finger gap in between. I just wanna make sure the spring rates I have are suitable for the current ride height I currently am at. And most importantly, its suitable for a DD car. Right now, my rear is bouncing up and down like crazy because of blown shocks. Front's still have some life. I'm ok with stiffness...Stiffness is ok. Just can't take the tremendous bounciness I'm currently dealing with.
Thanks!
- DM
Thanks!
- DM
#610
This is my ride...
Thanks!
- DM
Thanks!
- DM
#613
^ I did test drive my post, but either way, whether it were inserting an image or web link, it required a URL. I didn't see any other way of attaching pics, so I just chose one of the two.
#614
Thanks,
- DM
#615
If handling is the goal, you generally don't want to deal with progressive rates. If a lowered street car is the goal, use the bumpstops. They're a fantastic tool for allowing small bump compliance yet preventing bottoming out on the big ones. Requires a bit of measuring and sourcing parts though.
#616
If you can't make use of bumpstops as I described, probably 1" up to be safe. If you can, you can go to flushed tires with those rates. It really depends on the road conditions and how fast you intend to drive over things like potholes and such.
Thanks,
- DM
PS - I also have a set of Progess CSII coilovers, 450 all around. Perhaps this will work better?
#618
But what about Megan suspension? I've heard good things about them, the EZ streets in particular from someone who's car was dd/autox, and they are pretty affordable at about $700
#620
Megan Racing, didn't mean that they only make suspension components, I was just referring to the suspension products by Megan, but thanks for your opinion, what r they comparable to? Complete **** or like function forms? http://www.meganracing.com/products/special.asp?special_id=2
There they are in case you've never seen them, idk how to make it a clickable link tho
#623
Great write up about shocks and springs.
I was just interested to know what your ride height is and what ride height do you recommend for a daily driven civic?
I may plan to turbo the car down the road and might do some tracking but not 100% sure.
What bushings should also be replaced if I want that nice even look when the car is sitting still.
I need a spring rate that is still safe for winter driving
#625
Thanks for all the information it has helped me lots on the brand choice for my suspension setup. i have a 97 Del sol with B18C5 swap. i drive quite aggressively and this car only sees warm dry pavement. my budget was about $800 but im pretty certain i have decided to move up to the koni/GC "Honda-tech kit" with top hats offered by Ground Control for $1050 (and wait another month) however i know i want to go low (near total elimination of tire gap) and stiff (no bouncing up and down and little to no lean in corning) i am looking for a mostly nuetral setup leaning more towards a VERY slight oversteer and from what i understand i wanted to be near the 500lb/in spring rate in the front and back but the highest rate offered in the kit is 430lb/in front and back. i have good feeling that Ground Control honestly believes this is enough for what their design is, but i am curious if that sounds fitting for what i am hoping it will do for me.
