Old 08-09-2011, 08:41 AM   #1
Libertariat
Ek Forever y0!
2000 Honda Civic
Libertariat's Avatar
Send a message via AIM to Libertariat
Default Worn out window molding
Hi there. Just wanted to get some other heads on this to make sure I'm buying the right part before I pull the trigger and spend $150 getting these door moldings.
The rubber seal enveloping the driver's side window is old and worn out and the rubber sticks to the window and the molding gets yanked down when I roll the window down. Since I'm going to replace both the driver's and passenger's windows I just wanted to be sure that Illus. 1 and 3 are what I need. And do I need the Illus. 9 clip also? Or can I reuse my current one?
OMG LIBERTARIAT FINALLY HAS A BUILD
Need help choosing suspension? Click here!!
Finally for sale! Progress CS-II Coilovers (350/350) setup. Great for daily and entry/mid level autocross. Landed a 1st place win with these on 3/24
H23A w/ MFactory ITR trans 211whp 169ft/lb Stock block.
Libertariat is offline   Reply With Quote
Old 08-09-2011, 08:46 AM   #2
hyperblu
1999 Honda Civic
hyperblu's Avatar
Default Re: Worn out window molding
The clip should be metal and not need to be replaced.. however, there is a felt strip between the rubber flap and the window that has probably worn down smooth and causing the sticking. I would pull it out and inspect it first... Also, 1 and 3 are what you need, but if you purchase the rubber molding, the clip comes with it... the "9" is only if you need it seperately. We have this in stock at my dealership and i pulled it to look. it comes with the clip for sure.
hyperblu is offline   Reply With Quote
Old 08-09-2011, 09:01 AM   #3
Libertariat
Ek Forever y0!
2000 Honda Civic
Okay great. And I think your assessment is correct, that the felt has worn smooth and the adhesive holding it on is what is gunking up my window. I had to roll the window down for autocross last weekend since I can't see out of it very well. Hard to look ahead when your window is covered in grease.
The crappy part is that I'm going to have to get my windows re-tinted. My tint is showing it's age, so not a big deal, but the gunk left on the window is nearly impossible to remove. Might as well get my tint done once I replace the moldings.
They just pop in and out, correct? A buddy of mine was speculating that they might be riveted to the door. But he drives an EF
Edit: It's only $133 after shipping and handling. Bout the same cost from your dealer I presume?
Old 08-09-2011, 09:01 AM   #4
RonJ@HT
Raising the bar
2000 Honda Civic
My Garage
RonJ@HT's Avatar
I recently had the same problem. What you need to replace may actually be the door run channel (parts 6 or 11 in diagram).
Don't guess, troubleshoot.
RonJ@HT is online now   Reply With Quote
Old 08-09-2011, 09:06 AM   #5
Libertariat
Ek Forever y0!
2000 Honda Civic
When I roll the window down I can see the middle of the window catching on the bottom seal and yanking the bottom molding down with it. It sticks to the window and flips down dragging the whole molding over.
Old 08-09-2011, 09:07 AM   #6
RonJ@HT
Raising the bar
2000 Honda Civic
My Garage
RonJ@HT's Avatar
Yeah, that's the inner weather strip (part 3). I've had to replace that as well.
I think the part in your diagram in the first post is actually the outer door molding.
Old 08-09-2011, 09:22 AM   #7
94eg!
94eg!'s Avatar
So far we've got the inner, outer and channel molding. Figuring out which one is messed up should be easy. Then it's just a matter of ordering the correct part.
BTW: The outer moldings 1 & 3 in the very first picture come with the new #9 clips. Whenever a line is shown connecting multiple part numbers like that, they are being sold as an assembly on the number farthest out (in this case #1 & 3).
HE>i
94eg! is offline   Reply With Quote
Old 08-09-2011, 09:23 AM   #8
Libertariat
Ek Forever y0!
2000 Honda Civic
Yeah that makes sense. The number is included in the diagram markings. hyperblu cleared that up
Old 08-09-2011, 11:36 AM   #9
hyperblu
1999 Honda Civic
hyperblu's Avatar
If you need part numbers or need me to look in inventory for something specific just pm me. Im a tech and work in parts as well and always have an updated epc...
Old 08-09-2011, 03:45 PM   #10
motegicivic
Part 3 how does that come off? is it attached to the inner door panel?
Mine is messed up too, there is gunk getting on my window.
motegicivic is offline   Reply With Quote
Old 08-09-2011, 04:41 PM   #11
98civdx
Master Detailer
98civdx's Avatar
#3 has little "prongs" that attatch it to the door pannel.
The pannel has slots in, the prongs go threw, and you simply bend the prongs over to hold them on.
RIP Michael Young. 3-26-1991 9-2-2013
98civdx is offline   Reply With Quote
Old 08-10-2011, 01:00 PM   #12
motegicivic
I think I rem, there a lot of the prongs right?
To take off the old one you bend the prongs straight and pull of right?
Is there a clip, the pic shows a clip too?
Old 08-10-2011, 04:00 PM   #13
98civdx
Master Detailer
98civdx's Avatar
yes, you bend them straight, and simply pull the peice. There are quite a few of the little guys on there.
I didn't notice a clip on mine.
1995, 2002, 96, 97, civic, clips, door, exterior, gunk, honda, molding, moulding, outer, trim, windo, window, windows
