fast/easy fix for a stripped hole in the frame?
Old 08-08-2011, 11:25 AM
maxogsr's Avatar
Default fast/easy fix for a stripped hole in the frame?
I just notice that my front passenger torque mount has a stripped bolt there... It's in the frame and not very accessible to tap...not much room there... Anyone has an easy fix?
Old 08-08-2011, 11:34 AM
kyden's Avatar
Default Re: fast/easy fix for a stripped hole in the frame?
cut a hole in the rail, then weld it back up.
Old 08-08-2011, 12:03 PM
maxogsr's Avatar
that's the long fix... I know it's gonna end up like this...
Old 08-08-2011, 01:51 PM
RickyLee53's Avatar
Drill and tap bigger size, not going to get much easier. Access isn't bad if you can get the car on a ramp/jack and use an extension on the tap.
Old 08-08-2011, 01:58 PM
ronald55555's Avatar
I would helicoil it if possible, that way you can still use the oem size fasteners and won't have 1 oddball fastener.
Old 08-09-2011, 02:47 AM
maxogsr's Avatar
Sorry for my ignorance, but what's an helicoil?
Cause right now, the easiest I though will be to drill an hole on top and use a long screw and catch it from there...
Old 08-09-2011, 01:48 PM
RickyLee53's Avatar
If you do that, please post pics in the "worst fab thread". Seriously, don't do that. Helicoil is like a spring. You have to drill bigger, tap then insert. It'd be easier to drill and tap to the bigger size.
Old 08-09-2011, 02:39 PM
maxogsr's Avatar
Hey! I'm a racer so it dosen't have to look good...I just want my gear to get in when the car is load and I have to shift... It need to be fix for now... I'll cut and weld next winter!
I tried to find an extension for the tap but it seems to be hard to find... I did a couple store and couldn't find any...
Old 08-09-2011, 05:27 PM
k24em2's Avatar
Drill it out and nutsert
Old 08-10-2011, 06:56 AM
that-guy's Avatar
open the hole and just weld in a nut if its function over form. simple fix, and will only be as strong as the weld is thats holding it there
Omega Blaze
06-12-2014 05:13 PM
aimbot
04-29-2009 02:08 PM
acmoc
13
12-20-2008 11:12 AM
DOHC Kid
06-08-2008 05:55 PM
DA6mike
Welding / Fabrication
14
08-24-2006 09:54 AM
Quick Reply: fast/easy fix for a stripped hole in the frame?
