Freon Leak
Old 07-22-2011, 07:14 PM
curtie94's Avatar
Default Freon Leak
I have a freon leak around the compressor. The system was charged then it was empty within 2 days. The dye that I put in was all around the compressor. I was just courious if a leak in the compressor was fixable. Could a leak from a O-Ring cause that much freon to leak out?
Old 07-23-2011, 12:07 PM
poorman212's Avatar
Default Re: Freon Leak
Yes, if the seal at where the lines is blown then new seals may fix it.....if it is coming out the sahft seal....well that can be replaced but much more difficult.
Old 07-23-2011, 03:32 PM
curtie94's Avatar
How can I tell where it is coming from, the compressor is below the alternator.
Old 07-23-2011, 04:18 PM
curtie94's Avatar
I looked at the compressor and there is a rubber plug that isn't plugged in in, I can't plug it back in so could that be source of the leak?
There is some oil around the fittings on the compressor that the low side line connects to. But there is a lot of oil on the bottom of the compressor could all of the oil come from that fitting or is there another source that I can't see?
Old 07-23-2011, 09:51 PM
nus_dogg's Avatar
Clean it well and watch where it's coming from again from day to day.
Old 07-24-2011, 06:37 AM
poorman212's Avatar
Got any pic's of where this "plug" goes?
Old 07-24-2011, 08:57 AM
HonBeer's Avatar
Your car does not use "freon". It uses R-134a refrigerant. "Freon" is not made anymore because it depletes the ozone layer.
Old 07-24-2011, 09:39 AM
poorman212's Avatar
And thank you for that very constructive feedback. Not sure how that very insightful information is going to really help the OP solve their issue but you knew that and isn't anything new.
"Unless you have something constructive to add keep it to yourself"
Old 07-24-2011, 11:29 AM
nus_dogg's Avatar
Yeah, it's not freon. It's SUVA that are used in R134A system.
Old 07-24-2011, 01:34 PM
MiG-21 superfan
builthatch's Avatar
it's informative and technical in nature. from this point forward the OP will now know something he didn't before he created this thread, and others might as well. calm down.
Rick1t
05-06-2013 06:03 PM
hatrick
10
07-03-2012 10:30 AM
minvikes
07-11-2011 12:06 PM
rich_one1
12
07-08-2011 07:30 AM
lakerschamp2000
05-27-2009 03:01 PM
Quick Reply: Freon Leak
