Compliance bushing replacement?
Old 07-21-2011, 09:41 PM
astr627's Avatar
Default Compliance bushing replacement?
I went to dealer today to do inspection on my 04 accord v6. I just bought it with 120k mile.
After inspection they told me the car is in very good shape but front compliance bushings need to be replaced. I did see the crack in the rubber bushing, the passenger side has 1 inch(?) crack.
I have no idea on this problem, so should I do it immediately or just leave it there?
Old 07-21-2011, 11:41 PM
jakefrom's Avatar
Default Re: Compliance bushing replacement?
From what ive heard is the bushings are okay for a little while. (Again just what ive heard) Its there to keep the dirt out. Im gonna try to find a sealant of some sort instead of replacing mine which is the same one and same size crack.
Old 07-22-2011, 07:05 AM
astr627's Avatar
Dealer told me if bushings are bad, it's likely to damage wheel/tire, causing alignment problem. Also it will damage the lower control arm. The part is cheap, but labor cost almost 400. So that's why I'm not so sure about it. Do you know the normal cost for bushing replacement?
Old 07-22-2011, 06:31 PM
soon2bdropped's Avatar
400.00 seems about right.. to remove the arm and press the old bushing out and press the new one in. vehicle will wander while driving.. meaning it will pull back in forth in either directions. especially over bumps.
Old 07-22-2011, 10:51 PM
DCFIVER's Avatar
.... Its there to keep the dirt out. Im gonna try to find a sealant of some sort instead of replacing mine which is the same one and same size crack.
Wrong.
Old 07-22-2011, 10:55 PM
DCFIVER's Avatar
Try a Honda/Acura indy shop. They may do it cheaper. There is a tool available (I have one) that can be used to R and R the bushings with out removing the entire arm.
Old 07-23-2011, 06:30 PM
astr627's Avatar
That's what I'm thinking of. Indy mechanic can do it too. Not a hard job.
Old 07-24-2011, 08:17 AM
jakefrom's Avatar
Wrong.
My bad i didnt see he meant entire bushing just thought the boot for it
Old 07-29-2011, 05:52 AM
DeanHondaPGH's Avatar
When the bushings break all the way. You will know. The car will handle like sh*t. It may make some noise as well. If you have a good set of hands you can do them yourself. Then when you get them out make sure you mark the slits on the rubber with a paint pen or a sharpie, just draw a line on to the lower control arm. Take it to a machine shop or anyone with a press and pop the old one out and pop the new one in. Just make sure they go in the same way they came out.
Old 07-29-2011, 05:53 AM
*** when you get the arms out mark the direction of the slits in rubber***
Old 12-17-2011, 02:04 PM
astr627's Avatar
thank you
Old 12-17-2011, 02:27 PM
redbull-1's Avatar
This is the similar tool DCfiver is referring to. Snap-on and a one or more other companies makes one too.
http://www.sptool.com/index.php?page...mart&Itemid=11
skowsik
11-23-2017 09:39 AM
Telecatster
Suspension & Brakes
13
03-25-2013 06:53 AM
Octanum
02-28-2012 12:14 PM
CerealWars
Suspension & Brakes
09-28-2007 07:50 PM
Quick Reply: Compliance bushing replacement?
