Old 07-18-2011, 01:43 PM   #1
integratyper1990
integratyper1990's Avatar
Send a message via AIM to integratyper1990
Default 99 Si check engine light question - where is plug for scanner tool?
How do you get the check engine light codes that start with the P101 example
I have a 99 honda Civic EX with a 99 SI ECU GS-R Swapped Where is the plug for the scanner tool to go into (obd2 plug)
I know how to check it with the two pin plug= if i do it this way are the codes still the same
integratyper1990 is offline   Reply With Quote
Old 07-18-2011, 01:47 PM   #2
RonJ@HT
Raising the bar
2000 Honda Civic
My Garage
RonJ@HT's Avatar
Default Re: check engine light questiond
For some CEL codes, you get more information from the OBD2 code than from the OBD1 code. It's near the hood release lever:
Don't guess, troubleshoot.
Old 07-18-2011, 01:48 PM   #3
integratyper1990
Thanks man.
99, check, civic, codes, crv, ecu, engine, engines, honda, light, obd2, plug, scan, scanning, si
