Old 07-16-2011, 04:19 PM   #1
PreyStayShun
PreyStayShun's Avatar
WhoGunEssMyDee PreyStayShun
Default What Kind of Brake Fluid Are You Using
Getting ready to re-do my brakes, including stainless lines etc...
As mentioned...what kind of brake fluid are you all using? Any good suggestions?
DB Squad #355 <3 La Flama Blanca Build
PreyStayShun is offline   Reply With Quote
Old 07-16-2011, 04:27 PM   #2
Drive 4 fun
Default Re: What Kind of Brake Fluid Are You Using
ATE blue and alternate Gold to easy fluid change. Readily available off the shelf and good temp rating dry and wet. There are charts on HT with temp ratings and ATE is good, not the best. I have not had it fail or boil.
Drive 4 fun is offline   Reply With Quote
Old 07-17-2011, 05:09 AM   #3
rico05
1994 Acura Integra
Motul RBF600.
rico05 is offline   Reply With Quote
Old 07-17-2011, 06:24 AM   #4
Billy13
depends on what you are doing with the car, you dont need high temp stuff unless you run track days.
street driving and autox all you need is valvoline synthetic
tracking the car i use pentosin racing fluid.
Billy13 is offline   Reply With Quote
Old 07-17-2011, 07:03 AM   #5
Spawne32
Spawne32's Avatar
iTrader Rating: (3)
Send a message via AIM to Spawne32
valvoline synthetic dot3/4
DDTECHCAMS.COM - CNCWERX - OSIDETIGER - SPEED TRAPP CONSULTING TURBOS - SKUNK2
Originally Posted by 95LTX
my car hasnt had 02 sensors in.. forever. it roams around in a open loop speed density tune. killing small children and raping helpless mothers at night.
Spawne32 is offline   Reply With Quote
Old 07-18-2011, 04:13 AM   #6
Dogginator
Daisy... Daisy...
1997 Acura Integra
Dogginator's Avatar
I use Motul RBF600.
Its cost and properties guided this decision.
This is from an old version on StopTech's site.
Arranged by DRY boiling point:
DRY: 401F -- WET: 284F --- DOT3
DRY: 446F -- WET: 311F --- DOT4
DRY: 502F -- WET: 343F --- Valvoline SynPower
DRY: 509F -- WET: 365F --- Motul 5.1
DRY: 527F -- WET: 302F --- AP Racing 551
DRY: 536F -- WET: 392F --- ATE Superblue/TYP200
DRY: 590F -- WET: 410F --- AP Racing 600
DRY: 590F -- WET: 518F --- Castrol SRF
DRY: 593F -- WET: 420F --- Motul RBF600
DRY: 610F -- WET: 421F --- Neo-Synthetic Super DOT 610
Arranged by WET boiling point:
The SRF was the best, but it was absurdly expensive.
404: Care not found.
Dogginator is offline   Reply With Quote
Old 07-18-2011, 04:38 AM   #7
90efb16
1999 Honda Civic
My Garage
90efb16's Avatar
iTrader Rating: (7)
Honda genuine brake fluid dot 3
BUY MY SH$T!!!! PLEASE (DC SQUAD V3 #21)
http://hondamarketplace.com/showthre...1#post48921215####
90efb16 is offline   Reply With Quote
Old 07-18-2011, 08:31 AM   #8
Drive 4 fun
"I use Motul RBF600."
What is the cost and can you walk into a vendor and pick it up, or order ahead?
Old 07-18-2011, 08:39 AM   #9
Dogginator
Daisy... Daisy...
1997 Acura Integra
Dogginator's Avatar
It's about $15/500ml online. A local speed shop may carry it.
Old 07-18-2011, 08:55 AM   #10
Drive 4 fun
Fortunately, I have not overheated ATE. Bang for buck, ATE is about $12-13/L, enough for a flush. I can find it in a few places locally, mostly blue and usually ATE 200. I thought the price break is at ATE in the chart above. Wet point gets decent at ATE also.
Old 07-18-2011, 12:35 PM   #11
s2r
1998 Acura Integra
My Garage
s2r's Avatar
I use ATE blue on my car and not had any problems driving on street, canyons, track. The nice thing with the ATE Blue is you can see clearly when you are done flushing it, and it pretty inexepensive. It is also available in a yellowish color for the future change overs. My friend uses it in a race m3 and never had a problem either.
s2r is offline   Reply With Quote
Old 07-18-2011, 12:44 PM   #12
MoreCowbell
MoreCowbell's Avatar
Pensoil synthetic
MoreCowbell is offline   Reply With Quote
Old 07-18-2011, 01:00 PM   #13
1998GsRIntegra
1998GsRIntegra's Avatar
ATE Super Blue or AP Racing, just my preferences.
/// TAS Wheels
www.TASwheels.com
1998GsRIntegra is offline   Reply With Quote
Old 07-18-2011, 06:42 PM   #14
Drive 4 fun
Another note on Valvoline Synpower. The information in the chart is the old, original, formula. A few years ago they changed the look of the bottle and the formula. Dry boiling is 480F and wet 330F, off of the bottle, in my hand. I contacted them to confirm this, again a few years ago, and they had reformulated and confirmed 480 dry and 330 wet. I switched to ATE.
Old 07-19-2011, 02:11 AM   #15
Robinjo
This is what I run as well for Autocross. Change it every off-season because it doesn't work as well when it absorbs moisture. The two tones make it easy to tell when you have all the old fluid out.
For my daily driver I just whatever crap is on sale at the parts store...
Those running Motul, are you flushing every year as well?
1995 Integra GSR BG-33P ST-16
B20 1990 Civic Sedan
Robinjo is offline   Reply With Quote
Old 07-19-2011, 04:37 AM   #16
Dogginator
Daisy... Daisy...
1997 Acura Integra
Dogginator's Avatar
I flush every year with Motul.
The chart data that I posted shows that the Motul RBF600, ATE, and AP Racing 600 are all competent fluids for competition use. For daily use, run a DOT 3 or 4 fluid.
Dot 3 and 4 fluids are completely miscible and compatable with your system. Do not run a DOT 5.
Old 07-19-2011, 08:48 AM   #17
TOO MUCH TORQUE
TOO MUCH TORQUE's Avatar
prestone from walmart
TOO MUCH TORQUE is offline   Reply With Quote
Old 07-19-2011, 02:50 PM   #18
sc34dc4
1994 Acura Integra
My Garage
sc34dc4's Avatar
iTrader Rating: (1)
ATE typ 200 "gold" I order from north american motorsports. It's $12 and shipping is cheap.
Ban the DEED not the BREED. Proud owner of an APBT
Honda Tech newbs have made me lose all hope for humanity!
2NR0066 IS A BAD SELLER
sc34dc4 is offline   Reply With Quote
Old 07-19-2011, 03:19 PM   #19
Jimmy
Global Moderator
1994 Acura Integra
Jimmy's Avatar
iTrader Rating: (2)
dangjimmy
JDM ITR 36mm 5 lug conversion, Spoon Calipers, Hawk HP+ pads in the front, OEM Honda Type R pads in the rear. Stainless steel lines front/rear with ATE Blue fluid.. just had it out on the track all day Sunday.. no issues
Check out ImportDPS for good deals and all the sponsors in the marketplace usually have the cheapest prices
http://www.honda-tech.com/member.php?u=999596440
2004 Acura TL - Daily
1994 Integra RS - Track car
instagram: @jimmydudley
My build thread: 94 Integra RS sloow build-up
Originally Posted by Danza
The Man can't hold you down when you're flossing the bright green belts dawg
Jimmy is offline   Reply With Quote
Old 07-19-2011, 03:27 PM   #20
TheShodan
TheShodan's Avatar
iTrader Rating: (6)
Send a message via AIM to TheShodan Send a message via Yahoo to TheShodan
Motul makes a Dot 5.1 for street use I've been runnning for about 3 years on my wife's wilwood civic SI
“Don't let the opinions of the average man sway you. Dream, and he thinks you're crazy. Succeed, and he thinks you're lucky. Acquire wealth, and he thinks you're greedy. Pay no attention. He simply doesn't understand.” -Robert G. Allen
TheShodan is offline   Reply With Quote
Old 07-20-2011, 06:30 AM   #21
Dogginator
Daisy... Daisy...
1997 Acura Integra
Dogginator's Avatar
DOT5.1 is not the same as DOT5 (silicone based). DOT5 is hydrophobic, so water will phase seperate in the lines and can cause vapor issues. I personally do not like the DOT5.1 designation, as it will lead to someone thinking that DOT5 is OK to use.
http://en.wikipedia.org/wiki/DOT_5.1
Old 07-20-2011, 04:30 PM   #22
SleepyPanda
SleepyPanda's Avatar
i personally use Motul RBF600 or ATE super blue. but IMO if its your daily dot3 will be just fine.
SleepyPanda is offline   Reply With Quote
Old 07-20-2011, 04:33 PM   #23
battmancjz
Valveline synthetic
battmancjz is offline   Reply With Quote
Old 07-20-2011, 04:48 PM   #24
00IntegrAllmotoR
HT Black OPs
00IntegrAllmotoR's Avatar
iTrader Rating: (1)
Motul DOT5.1- Daily
Motul RBF600- Track Use
DB Squad Member #24
FS Thread: http://hondamarketplace.com/showthread.php?t=2970420
00IntegrAllmotoR is offline   Reply With Quote
1990, 2002, 95, acura, brake, city, civic, fluid, honda, integra, kind, lxi, tech, type, z
