Go Back   Honda-Tech > Honda and Acura Technical Forums > All Motor/ Naturally Aspirated
Old 07-12-2011, 12:35 PM   #1
HellaFab
1992 Eunos Roadster
My Garage
HellaFab Hellafabrication
Send a message via MSN to HellaFab
Default Milling piston dome to lower compression ratio?
Looking at building a reliable B20Vtec for daily use and i was considering RS machine pistons.
The only problem is that they would put me at too high of a compression ratio for 91 pump.
The question is, is it an acceptable practice to machine the dome/valve clearance portion of the piston down to reduce compression?
I havent been able to find thicker head gaskets for the B20.
HellaFab is offline   Reply With Quote
Old 07-12-2011, 12:41 PM   #2
FlewByU352
FlewByU352's Avatar
Default Re: Milling piston dome to lower compression ratio?
I thought those pistons are only in the 11's? 12:1 can definitely be done on pump without a problem.
FlewByU352 is offline   Reply With Quote
Old 07-12-2011, 12:48 PM   #3
egb18c5
egb18c5's Avatar
cometic makes thicker head gaskets. give them a call.
as far as compression goes, buy the pistons first and then see what you get. you should be within the compression range that they provide.
from my research, getting "exact" specs for these pistons are not as easy as most think. rs machine themselves are no help. you can try using different inputs that would yield more or less the number they say you will have but it would be better off if you did everything yourself to figure out exactly what your working with.
Perfection is perfected.
egb18c5 is offline   Reply With Quote
Old 07-12-2011, 03:53 PM   #4
SP GARAGE
SP GARAGE's Avatar
iTrader Rating: (1)
ALLMOTORH2B
Send a message via AIM to SP GARAGE Send a message via Yahoo to SP GARAGE
Plenty of people use these pistons on 91 oct... Has the block been decked to much or the head milled??? Only real reason I can see why you can't use pump... If all else fails get a cometic or u can add a layer or 2 to the headgasket
DD TECH camshafts*QSD* SYNCROTECH TRANSMISSIONS*PROSTREET IMPORT*FOREVER ASHBURY
SP GARAGE is offline   Reply With Quote
Old 07-12-2011, 04:34 PM   #5
.Manny.
Touching My Member
1990 Honda Civic
.Manny.'s Avatar
I have those pistons and I'm tuned on 91.
Originally Posted by doctorake View Post
This thread is worse than sucking ten dicks at once.
.Manny. is offline   Reply With Quote
Old 07-12-2011, 07:06 PM   #6
tempsohc
tempsohc's Avatar
main things to be reliable are.
12.0 or less on 91 octane
Good tune
Arp rod bolts,type r oil pump and water pump
anything past taht would be preference on how much power you really need.
DRAMA QUEEN! watchout DIVA ONBOARD
tempsohc is offline   Reply With Quote
Old 07-13-2011, 05:01 AM   #7
HellaFab
1992 Eunos Roadster
My Garage
I was hoping to just be in the 11.0:1 -11.3:1 compression.
They state that i would be 11.7-12:1 (depending on head, so with b16 head i assume 11.7. gsr being the 12.0)
I dont want to push the limits on 91 incase for some reason i get a bad batch... for example on the drive to my cottage in some strange little town.
i will contact cometic but i think i need a 1.4mm headgasket to get the compression i want, which would change the cam timing fairly signifigantly.
is there any differences of the typeR oil pump to the EM1 b16 oil pump?
Edit.... down the road i would like to add some skunk2 pro2 cams (i think that is the best for a 2.0L?) and dont want to have any issues with piston to valve clearance, so maybe the headgasket would be best...
Old 07-13-2011, 10:43 AM   #8
96dxB16
96dxB16's Avatar
Send a message via AIM to 96dxB16
I would leave compression where it is. If you're worried about a bad batch of gas killing your motor at 11.7:1 ratio; 11.0:1 ratio isn't going to save you.
96dxB16 is offline   Reply With Quote
Old 07-13-2011, 10:55 AM   #9
FlewByU352
FlewByU352's Avatar
Yeah a bad batch of gas is going to kill ya either way. Also don't fill up in some strange little town if they have el cheap o gas. I literally will only put Shell 93 octane in my car. If I am not in a familiar area and I am running low, I GPS Shell and will drive 10 miles out of the way to fill up.
Old 07-13-2011, 06:05 PM   #10
.Manny.
Touching My Member
1990 Honda Civic
.Manny.'s Avatar
You're over thinking it.
Old 07-13-2011, 06:41 PM   #11
2k.civic.si
2k.civic.si's Avatar
just build it with those pistons and enjoy 0.5 point of compression isnt going to make any real difference
EFI University Certified Advanced Tuner http://www.artietuned.com
Ecu chipping,Street/Dyno tuning,Crome Pro/Gold,AEM,FAST,Motec, and more.
www.westcoastnationals.org
2k.civic.si is offline   Reply With Quote
Old 07-13-2011, 11:51 PM   #12
igorka_91
igorka_91's Avatar
iTrader Rating: (1)
x2.
my friends b20v with rs machine itr 84 mm pistons, s2s2cams on base map calli **** 91 oct put down 204 whp and ran 13.3s on slicks on a base map.
DD-1996 Integra LS.
Weekend warrior- 2006 Evo 9 2.4L 10.1CR 6765 e85 22psi 552awhp 455awtq
igorka_91 is offline   Reply With Quote
carve, comp, compression, decresed, dome, domes, heads, honda, kingston, lower, milling, ny, pistions, piston, pistons
