2004 Check engine Code p0135
Old 07-10-2011, 08:52 AM
antok86's Avatar
Default 2004 Check engine Code p0135
i got an engine check light about a month ago. I just now got it checked at autozone and it came up with a code P0135. Quick google shows that its "P0135 O2 Sensor Heater Circuit Malfunction (Bank 1 Sensor 1)" anybody know where exactly this sensor is located and if i can do it myself?
Old 07-10-2011, 09:18 AM
Plead da Fif
It Wasn't Me's Avatar
Default Re: 2004 Check engine Code p0135
P0135 on 2004/2005 models is Air Fuel Ratio Sensor (Sensor 1) Heater Circuit Malfunction...
If you have a D17A1, it's right on top of the manifold.
If you have a D17A2, it's just below where the manifold connects to the A-pipe. (also known as downpipe)
Yes, you can do it yourself.
Old 07-10-2011, 09:40 AM
antok86's Avatar
do you know what part number it is? should i replace it with an OEM or aftermarket is just fine.
Also is it just going to be the sensor? or should i even place the wiring harness too? or is it just one kit
Old 07-10-2011, 09:48 AM
Plead da Fif
36531-PLR-003 for EX http://www.hondaautomotiveparts.com/...PIPE+-+MUFFLER
36531-PLM-306 for DX/LX http://www.hondaautomotiveparts.com/...SOHC%2FVTEC%29
Results of people using aftermarket sensors are mixed. Some people have no issues (or simply have not updated their old threads after using an aftermarket sensor) while other people do. It's hit-and-miss, I guess.
Personally, if/when I need to replace one, I'm going to use an OEM sensor.
Old 07-10-2011, 09:51 AM
antok86's Avatar
thanks for help! is there any long term damage if i run my car with the error?
Old 07-10-2011, 10:05 AM
lazlong's Avatar
^^ Yes. It throws off the air/fuel mixture which may lead to disastrous consequences (burnt valves, pistons, etc.). Plus your fuel mileage probably isn't real good.
These Hondas seem to be pretty finicky about O2 sensors. Recommend biting the bullet and getting OEM. I know it's like $250 but, you can do it yourself with a $7 O2 sensor wrench available at any autoparts store.
Old 07-10-2011, 10:11 AM
antok86's Avatar
excellent. yea ill stick with OEM. link to o2 sensor wrench? cant i just use a cresent
Old 07-10-2011, 03:56 PM
lazlong's Avatar
Yes but, it's way easier with an O2 wrench.
Don't remember what size: http://www.harborfreight.com/catalog...esult?q=oxygen
Old 07-12-2011, 02:09 PM
antok86's Avatar
okay so i changed my sensor and my engine light is still on. is it supposed to go away imediately or do i let the engine run for a little bit?
Old 07-12-2011, 02:23 PM
GriFFIthS's Avatar
Youll need to have the Code Cleared, You can do that with a OBD2 scanner, but if you dont wanna do that a easy way would be to pull the #6 fuse in the engine bay panel(next to the battery) take out the fuse and wait a minute, put it back in and your light will now be off, assuming you fixed the problem that cause the light to begin with.
Old 07-12-2011, 02:34 PM
antok86's Avatar
well once cleared...if its not fixed im assuming it will light back on
Old 07-12-2011, 02:42 PM
Plead da Fif
Affirmative.
Old 07-12-2011, 02:43 PM
antok86's Avatar
Affirmative.
all cleared for now. will drive around the block in a bit
Old 04-17-2012, 06:32 PM
eight equals equals equals D
Tim2179's Avatar
Figured I'd bump this one since I also have a P0135 code on my wife's '04 Civic EX.
Found the OEM part for $230 from the dealer, but also seem to have found many on Rock Auto's site for ~$150. Is there a particular DESNO P/N that would work, or should I just get the OEM to be on the safe side. For some reason I thought DENSO was the OEM supplier.
Rock Auto HONDA O2 SENSORS
Old 04-17-2012, 09:10 PM
BlueKat's Avatar
You are correct (DENSO W0133-1828743)
Old 04-18-2012, 05:25 AM
Tim2179's Avatar
Anyone have any success with DENSO #234-9017?
Old 04-30-2012, 08:23 AM
ChicagoGuy_3344's Avatar
Anyone know what fuse it is? I want to check the fuse on my wife's car before I buy a $200 sensor. I changed all 4 sensors in my Jeep with a similar code and it ended up being a bad fuse/wire issue. Thanks.
Old 04-30-2012, 09:06 AM
Tim2179's Avatar
Installed this P/N and it worked fine.
Old 04-30-2012, 07:03 PM
PA04EXSedan's Avatar
I just installed 234-9017 tonight - $129.68 on Amazon
Dennin01
Acura TL, RL & ZDX
09-23-2018 07:17 AM
salaamq
01-07-2012 05:56 PM
mtime
12-17-2009 09:17 PM
dbailey
21
11-09-2007 07:08 AM
type r 01-1063
01-16-2004 11:52 AM
Quick Reply: 2004 Check engine Code p0135
