Go Back   Honda-Tech > Honda and Acura Model-Specific Technical Forums > Honda CRX / EF Civic (1988-1991)
Old 07-09-2011, 05:20 PM   #1
clonestocker
Default 1990 Civic CEL/ECU Problems?
Having some problems on my son's Civic. It's been over a 100 degrees here and the CEL has been coming on. If you check the LED on the ECU it's 1 lond flash and 16 short flashes. If you put a jumper wire in the 2 prong plug to check the stored code it does nothing. Also, it occasionally won't start. It will crank and crank but won't start. When it cools off outside the car starts fine. Please help! matt
clonestocker is offline   Reply With Quote
Old 07-09-2011, 06:46 PM   #2
OneBadTurboCRV
OneBadTurboCRV's Avatar
Default Re: 1990 Civic CEL/ECU Problems?
On 88-91's the codes are checked via the LED on the ECU. The connector is only for setting ignition timing.
'98 CRV EX
'13 Civic Si
OneBadTurboCRV is offline   Reply With Quote
Old 07-09-2011, 10:07 PM   #3
garthjenkins
hmmm.. yeah he is right about he blinks try counting again.
I had a ef civic hatch back in high school that wouldnt start if it was hot outside, would just crank and crank
but if it was a cold early morning she fired right up but no codes.....never did figure that one out
garthjenkins is offline   Reply With Quote
Old 07-10-2011, 06:27 AM   #4
jlicrx
jlicrx's Avatar
sounds like you, if you are counting correctly, have codes 1 for O2 sensor and 16 for fuel injector circuit - OBD0 D-series ECUs do not have long and short flashes, only short - make sure that you are counting correctly - the symptoms you describe would be consistent with a bad ignition control module (igniter) which would be a code 15 - ECU flashing 15 times - could also be a bad main relay - i would start by checking main relay
ZCspeed Racing
jlicrx is offline   Reply With Quote
Old 07-10-2011, 09:41 AM   #5
95GSRnj
95GSRnj's Avatar
Try replacing the PGMFI relay. My 1990 STD did the same thing when it was hot out sometimes I would drive to a store run in grab a soda come out and it wouldn't start, I replaced the relay and haven't had an issue since.
sometimes you're the windshield, and sometimes you're the bug
95GSRnj is offline   Reply With Quote
1990, 8891, 89, cel, check, civic, code, codes, computer, count, ecu, failures, flashing, honda, led, light, problems
