97 accord no start just click
Old 07-07-2011, 07:20 PM
vi3tzkidd's Avatar
Default 97 accord no start just click
I have try searching around the forum and I can not find the answer. The car will start like early in the morning and after I go to a place and turn the car off and than try to turn it back on it would not start but I do hear a clicking noise. BUT if I start the car with my remote starter instead of the key it will always start no matter what. I have replace the starter, spark plugs, distributor cap, air filter, tested the battery, and i know it cannot be the starter or battery since the car will start just fine if I use my remote starter.
Can anyone help? Sorry forgot to mention it is a 1997 accord lx non vtech i4
One more thing sometimes when I turn off the car and everything I made sure is off like the A/C and stuff, so I turn off the car and remove the key but my car sound like it is still running.
Old 07-07-2011, 07:32 PM
dglassmyer's Avatar
Default Re: 97 accord no start just click
Ignition switch?
Old 07-07-2011, 07:33 PM
vi3tzkidd's Avatar
I thought with an ignition switch it still try to crank but wont start? My car does not even try to crank all I hear is a click.
Old 07-07-2011, 07:49 PM
dglassmyer's Avatar
Icon5 Re: 97 accord no start just click
Well the sound your likely hearing is the gear inside your starter that engages the cogs on the flywheel being pushed forward to turn the motor over, however if your starter is bad, such as a flat spot on the commontator or weak springs pushing the brushes it will just click as power can't transfer through the starter, therefore it wont spin.
If that were the case I would say you have a bad starter.
But since you stated it will remote start consistently that can't be the case, try using the point your remote start plugs in and troubleshooting upstream of it for issues, ending with the ignition switch
Old 07-07-2011, 07:54 PM
vi3tzkidd's Avatar
Yeah I will probably test the igintion switch tomorrow with a continuity tester.
Old 07-07-2011, 08:01 PM
dglassmyer's Avatar
I just mentioned this to another guy and its basic but also make sure your ground cable is secure and in good shape
Old 07-07-2011, 08:52 PM
gogydm's Avatar
Manual or Automatic?
Old 07-07-2011, 09:24 PM
vi3tzkidd's Avatar
it is an automatic
Old 07-08-2011, 06:03 PM
nus_dogg's Avatar
Probably something in the primary starting circuit.
Old 07-08-2011, 08:45 PM
chikin pickle's Avatar
You have a bad starter. I had the same problem with mine. It happens at random, there is no logic or reason behind it. Get the starter tested.
Old 07-08-2011, 09:25 PM
gogydm's Avatar
Here is a link form a different forum http://www.cd5tuner.com/vbb/showthread.php?t=5322.
Old 07-14-2011, 10:42 AM
vi3tzkidd's Avatar
it ended up being the ignition switch but luckily honda replace it for free so really didnt cost me anything but thanks for all the help
kjrayo18
11-16-2015 08:26 AM
RichEd223
09-07-2008 07:26 PM
fanatic
11-05-2005 06:00 PM
Quick Reply: 97 accord no start just click
