HELP! Car suddenly overheating.
Old 06-30-2011, 09:22 PM
dlhtox's Avatar
Default HELP! Car suddenly overheating.
Thanks in advance for the kind souls that help me out!
I have a 1995 Honda Accord that suddenly started overheating today badly.
The air conditioning belt has been slipping for quite a while and getting worse.
While I was driving I noticed that my AC was not working, or working only slightly and then not at all, it started blowing hot air.
So, I thought.. well that belt must have given out, or is slipping so bad it's not working.
Then after driving about 6 more miles I started hearing some noises from the engine, nothing major, but enough to make me wonder. Then I noticed a lot of steam coming out from under the hood. I then noticed that the temperature gauge was pinned in the red.
I immediately pulled over and opened it, and it appeared a lot of the steam was coming from the reservoir near the radiator.
A few things.
Why would the air conditioning be related to the car overheating?
I did completely replace the radiator about 6 months ago due to a crack in the original one. Is it perhaps just too low on coolant? I thought I filled it completely, but I'm not necessarily well versed in these matters.
Can trouble with the AC belt cause the car to overheat, or is the AC stopping working all of a sudden indicative of something else?
What should I look for? What can I start doing? This is a BAD time to start having some car troubles, for many reasons.
Thanks so much for reading this.
Old 06-30-2011, 09:39 PM
Nicefeet's Avatar
Default Re: HELP! Car suddenly overheating.
Cooling fans died
Old 07-01-2011, 07:13 AM
nus_dogg's Avatar
Originally Posted by dlhtox
A few things.
The A/C compressor is driven by the engine, so if you turn the A/C system on, the engine will have to work harder just by driving the A/C compressor; as a results, overheats. This will only happen if the A/C belt is still on the car. Both fans will need to be in working condition because as the engine works harder, more heat as its being work harder.
Old 07-03-2011, 10:33 AM
poorman212's Avatar
Was this in stop and go traffic or while moving at speed > 20 mph?
Old 07-04-2011, 06:22 PM
ricebike's Avatar
in hindsight
i hoped you burped the air out of the system after you replaced the radiator...
and hoped you confirmed that BOTH fans turn on when you hit your AC button...
now, after you have seen the temp gauge in the RED and saw steam coming out of the reservoir, you have to worry about a blown head gasket, warped cylinder head, etc.
crazycabana
06-16-2011 10:57 AM
davidfillups
12-07-2010 02:20 PM
nickhans
10-28-2005 07:46 AM
s520player
12
09-03-2003 12:48 PM
airborne84000
16
01-29-2003 05:42 PM
Quick Reply: HELP! Car suddenly overheating.
