My B18C1 Engine Build/Assembly
Old 07-22-2011, 06:37 PM
  #251
Moderator
TheShodan's Avatar
Default Re: My B18C1 Engine Build/Assembly
FANTASTIC!!!!
Old 07-22-2011, 06:43 PM
  #252
No-Traction = Fun
CaliforniaDad's Avatar
Yeah!! atleast now I can drive it around and break it in and be checking for leaks and what not. I already found a tiny one on the back of the block where the oil feed and sensor is connected. Im fixing it as I type
Old 07-22-2011, 07:02 PM
  #253
Moderator
TheShodan's Avatar
BTW, where did you get the clock-located gauge cluster from?
Old 07-22-2011, 07:36 PM
  #254
No-Traction = Fun
Its from a member of honda tech, Ill get you his SN
Old 07-22-2011, 08:01 PM
  #255
No-Traction = Fun
Here you go ---> https://honda-tech.com/forums/members/luv2boost-999376842/
Old 07-22-2011, 08:11 PM
  #256
Moderator
TheShodan's Avatar
Thanks!!!! ;-)
Old 07-22-2011, 11:07 PM
  #257
rich7777's Avatar
Good stuff ! ! ! Try raising the idle upto 1200rpm and adding 25% duty cycle to the idle control valve. That should smooth it out a bit. You can + or - some ignition in the idle area of the map to.
Old 07-22-2011, 11:36 PM
  #258
turboda4dr's Avatar
Originally Posted by CaliforniaDad
I called up and spoke to Bo at AEM and we went thru and recalibrated a few things on the AEM EMS. It will get me by and allow me to put put just around town to put some miles on it before I go in for tunning in 2 weeks. And the moment you have all been waiting for.
http://www.youtube.com/watch?v=6pATNSFxcZo
thats a lot of gauges lol. very nice built!!
Old 07-23-2011, 12:55 AM
  #259
No-Traction = Fun
Yeah I like o be well informed......lol
Old 07-23-2011, 08:08 AM
  #260
bigsnorlax's Avatar
WOOOO! Just look at all those gauges light up ha, hope none of your friends have epilepsy..
Looking good though, great work on the car. Now throw it on them rollers!
Old 07-23-2011, 12:17 PM
  #261
ShanghaiOC's Avatar
Looks great, man! How will you keep yourself occupied until the tune? Any projects for the wife?
Old 07-23-2011, 03:18 PM
  #262
Organization's Avatar
im jealous got three engines in my back yard and no time lol
Old 07-23-2011, 10:56 PM
  #263
No-Traction = Fun
3 B18C's?
Old 07-24-2011, 01:34 PM
  #264
1 b18c with cracked sleaves(sending to GE), 2 ls block for ls/v one actual built with b16 ish piston's and ls rods with arp bolts I just havent had the time to put it together. and i have two gsr heads.
i've been messing with my friends b20 vtec getting it running right last night i was at the tracks testing it out
Old 07-25-2011, 05:22 AM
  #265
BigMike0147's Avatar
Looks good man! You did a lot of work in a short amount of time! LOL
One question though, how do you have your breather tank mounted?? I have mine in a similar spot, but I can't figure out how to mount it over there. Thanks
Old 07-25-2011, 12:04 PM
  #266
No-Traction = Fun
My breather kit isnt mounted yet either. I'm still working on that part.
Old 07-26-2011, 04:44 AM
  #267
Nice! LOL I'm glad to know I'm not the only one then.
Old 07-26-2011, 04:55 AM
  #268
No-Traction = Fun
I noticed today while putting around my oil light flickers a idle when my oil pressure is around 22-25 psi. Is this normal? My oil pressure is 65-75 when I driving
Old 07-26-2011, 05:30 AM
  #269
rich7777's Avatar
Have you got a loose wire on the stock sendor ? Your oil pressure sounds spot on.
Old 07-26-2011, 02:11 PM
  #270
No-Traction = Fun
Nope no loose wire. I think its because im not running the factory ECU, Im running AEM EMS and I think there is a setting in there that needs to be changed.
Old 07-26-2011, 05:38 PM
  #271
kyden's Avatar
the ecu has nothing to do with the oil light.
Old 07-26-2011, 09:28 PM
  #272
No-Traction = Fun
So than it must be a bad oil light, because Im getting 23-25psi at idle once warm and 70+ psi at 3000 rpm
Old 07-26-2011, 10:47 PM
  #273
rich7777's Avatar
Your oil pressure is fine and its nothing to do with your ecu. The stock sendor act's as a ground. Either its faulty or theres a bad connection somewhere.
Just think how bad you'd be pulling your hair out now if you didnt have a oil pressure gauge lol.
Old 07-26-2011, 11:29 PM
  #274
dgaf95integra's Avatar
good video
Old 07-27-2011, 07:37 AM
  #275
ShanghaiOC's Avatar
Amen! I had an issue on my old EF...it was a bad connection but luckily I had a nice Oil Pressure Gauage.
Quick Reply: My B18C1 Engine Build/Assembly
