My B18C1 Engine Build/Assembly
Old 06-26-2011, 07:33 AM
No-Traction = Fun
CaliforniaDad's Avatar
Default My B18C1 Engine Build/Assembly "The Black Pearl"
Well I started working on putting all my pretty pieces together yesterday so I thought I would use this thread to track my status. Ill update it as I go.
So far all I have done is clean and paint the block
Installed the oil squirters
Installed the main bearings
Installed the crank
Used plati-gauge on the main bearings .038mm or .0015" across all 5
Next I am going to install and check the rod bearing clearance's
MORE TO COME
Old 06-26-2011, 10:16 AM
1FASTHF's Avatar
Default Re: My B18C1 Engine Build/Assembly
Good $hit. I wish my lady would let me build my stuff in the house...lol
Old 06-26-2011, 11:44 AM
DAgsrt's Avatar
sweet keep this going man i am going to be doing the same thing soon. keep the pics coming. step by step.
Old 06-26-2011, 12:52 PM
racebum's Avatar
keep me posted if you want to do another build page, that last one you did here:
http://www.turboinstall.net/general-...a/drive-axles/
on axles has already helped a couple people
Old 06-26-2011, 08:38 PM
No-Traction = Fun
Hahah yeah notice the large blanket on the floor. Love my wife!
No-Traction = Fun
Right on man, Ill try and take as many pictures as I can. hope it will help someone.
Old 06-26-2011, 09:04 PM
Moderator
TheShodan's Avatar
Looks like its really coming along.
Old 06-27-2011, 08:40 AM
lsturbo33's Avatar
.038mm/25.4 = .001496" looks like your missing a zero. Just so nobody thinks your clearance is wrong.
Old 06-27-2011, 08:26 PM
No-Traction = Fun
I'm sorry you lost me?
thanks guys, once I get the pistons and rods figured out Ill continue the build.
Old 06-28-2011, 12:12 PM
lsturbo33's Avatar
Sorry, read your first post. You put .015". It should be .0015". To convert mm to inches you simply divide by 25.4. or multiple if your going from inches to mm. Your block is really clean... What did you use to clean it?
Old 06-28-2011, 06:52 PM
No-Traction = Fun
Oh hahaha, sorry It was late when I posted it. Yeah I used a bucket of how water and purple-power de-greaser. Then dried the block and painted it with self etching paint and then some gloss black engine paint.
Old 06-28-2011, 10:14 PM
rich7777's Avatar
Looking good ! Are you running those Wiseco's and forged rods in this ? If so you can block the oil squirters off. If you do want to run them then make sure you watch the clearence between the bottom of the piston skirt at the oil squirter. Good luck
Old 06-29-2011, 08:02 AM
No-Traction = Fun
yep, I plan on keeping the oil squirters as it is my daily driver. I will make sure I have plenty of clearence when I install the pistions. Wiseco gives me the specs for that on the tech card.
Old 06-29-2011, 08:58 AM
rich7777's Avatar
To be honest whether it be a daily driver or what ever i don't think there needed with forged pistons. Everyone i know just blocks them off. If you choose to run them you'll have to bend them (without snapping one) to get the right clearence.
Old 06-29-2011, 09:44 AM
Moderator
TheShodan's Avatar
It's not a necessity to keep them at this point. But since you have everything to work with the GS-R, there's nothing wrong with keeping them. The pistons should clear without a problem because you don't have any change in stroke.
Old 06-29-2011, 10:01 AM
rich7777's Avatar
I'm not sure about the clearences been ok Mac. I have seen them stuck to a magnetic sump plug in the past because the clearence wasnt checked. This engine was a ITR B18c though (standard stroke). I assume the pistons will be the same design wise as the engines more or less are. I could be wrong though....
Old 06-29-2011, 10:12 AM
Moderator
TheShodan's Avatar
Its possible. On my fully sleeved B18C1, Pistons/rods, all clear the squirters. Been like that about 10 years now. But again, if he changed stroke, I'd be more concerned.
Old 06-29-2011, 10:36 AM
racebum's Avatar
last engine i blew up used mahle pistons and the squirters had to be bent a bit to clear the piston and leave reasonable clearance. long story short : check clearance
Old 06-29-2011, 10:54 AM
Moderator
TheShodan's Avatar
This is a given for Californiadad, so I think we can all rest with that.
Old 06-29-2011, 12:56 PM
No-Traction = Fun
Oh yeah you can bet on that. I'm trying to build this thing by the book, since I'm not in a big hurry. Ask 10 questions, check and mesure 3-4 times then put together and re-reck and check.
Old 06-29-2011, 10:17 PM
rich7777's Avatar
Take a look at these video's when you get chance. I hope there usefull to you.
http://www.youtube.com/watch?v=mpy_By5aIxM
http://www.youtube.com/watch?v=MtTXA...eature=related
http://www.youtube.com/watch?v=JE7U5...eature=related
Old 06-30-2011, 03:58 AM
Moderator
TheShodan's Avatar
Good Call, Rich... Very informative!!!
Old 06-30-2011, 04:36 AM
rich7777's Avatar
Thank you, theres some really good info there. Its definatly worth a watch if you ask me. Jeff Evans sure knows his stuff so you can't go wrong hearing it off him.
Old 06-30-2011, 05:11 AM
No-Traction = Fun
Yep I watched those videos over and over about a month ago, I have them saved on my desktop for quick reference. hahaha
Old 06-30-2011, 05:29 AM
rich7777's Avatar
Good stuff lol, i had a feeling that you may have but thought they would still be worth posting up just incase.
Quick Reply: My B18C1 Engine Build/Assembly
