Go Back   Honda-Tech > Honda and Acura Technical Forums > All Motor/ Naturally Aspirated
Old 06-10-2011, 10:44 PM   #1
93_hatch
93_hatch's Avatar
Default valve clearance ?
so wondering what is a acceptable valve radial clearance / valve to piston releif side clearance? or engine build chime in with what you run for clearance? having trouble finding this spec
OutKast member since 2008
93_hatch is offline   Reply With Quote
Old 06-10-2011, 11:27 PM   #2
f20b jones
f20b jones's Avatar
michael jones
Send a message via AIM to f20b jones
Default Re: valve clearance ?
What motor are you building? Race motor ot street motor ? A little more info would help . What compression are you wanting to run ? I run a little closer clearences then most motors i build for other people for several reasons . I can tell when something isnt right and will tear my motor down and inspect it instead of keeping on beating on it. I also use a different method to check my clearences then anybody else and it makes me feel a little better seeing whats going on rather then checking the thickness of clay . I think 35 thousandth is a good squinch point but mine are at 26 thousandth. Im sure everybody has different ideas to each there own.
252hp and 34.5 miles to the gallon all motor. 12.2 at 111
f20b jones is offline   Reply With Quote
Old 06-10-2011, 11:33 PM   #3
f20b jones
f20b jones's Avatar
michael jones
I can turn my motors over with the vtec pin locked in and the valves will never touch the pistons . Its not hard to cut big valve reliefs the valve to valve contact is what you need to worry about and you cant control that just prey your timing dont snap . I have seen a timing belt that somebody pryed on instead of using the proper h tool snap at the track and destroy a head . Piston had small scratches but overall ok.
Old 06-11-2011, 09:37 PM   #4
93_hatch
93_hatch's Avatar
its a b16 with 11.5 pistons, more like 12 with block resurfacing and head resurfacing, and flat face valves. motor use some daily and some road race/autocross. current measurement with the vtec locked in, intake .070in and exhaust .060in that is radial clearance not depth, my depth is like over .120in don't remember that off the top of my head. and what are u talking about preyed on timing belt instead of using an h tool? sorry i am not smart enough to pry on a belt.... that just stupid.
Old 06-15-2011, 03:04 AM   #5
cibao2ner
cibao2ner's Avatar
.030 v2v is the standard minimum at 0 lash....
cibao2ner is offline   Reply With Quote
Old 06-15-2011, 07:08 AM   #6
GhostAccord
1996 Honda Accord
GhostAccord's Avatar
It is true that clay is not the only way to check valve clearances. I use a dial indicator with the head installed and test springs. There is also the feeler gauge method. As for clearances I usually shoot for 0.03" - 0.035".
Unfortunately the dial indicator and feeler gauge methods are useless for checking your clearances for your valve diameter or side clearance to the valve relief. This is important if you are using aftermarket pistons or over sized valves. You should use clay for that. Pistons can rock in their bores and they also expand in high temperatures.
GhostAccord is offline   Reply With Quote
Old 06-15-2011, 08:20 AM   #7
PyroProblem
1998 Honda Civic
My Garage
Facebook = too much drama and a waste of time
Borescope?
PyroProblem is offline   Reply With Quote
Old 06-16-2011, 10:19 PM   #8
93_hatch
93_hatch's Avatar
got answer from wisco since i am using there piston they said .060 is min and i am right at .060. would like to be a little more so i have peace of mind instead of right at the edge.
lol borescope that would be cool but not enough room in the cylinder for it. i guess i just have to hope my claying measurement was good.
Old 06-17-2011, 05:05 AM   #9
GhostAccord
1996 Honda Accord
0.06"......Is that their specs for the radial clearance or for both radial & vertical?
Clay is good enough when done & measured properly. Good luck with your build
Old 11-08-2011, 03:02 PM   #10
jasonwinback
j4s0n 89
i want to to notch my b20 piston using this technique http://www.fordmuscleforums.com/engi...-notching.html but the thing is to have a good clearance i would have to buy a 1.5mm oversized valve. my question is is there anywhere they sell them (as single valves would be prefered) and if you have any other sugestion let me know
jasonwinback is offline   Reply With Quote
Old 11-09-2011, 05:10 AM   #11
4piston
4piston's Avatar
Send a message via AIM to 4piston
Most piston manufacturers will tell you between .050"-.080" depending on who you talk to and that is just them being super safe.
IF your valvetrain is in control, you can run down to .020" radial clearance. .030" is pretty safe. Also make sure that your valve pocket is actually in the proper location on the piston.
CNC Cylinder Heads - K20/K24, B18C, B16, H22, S2000, EVO ->www.4piston.com
Luke@team4piston.com
Like us on Facebook!! http://www.facebook.com/4Piston
4piston is online now   Reply With Quote
2002, 24, b16, face, flat, lash, piston, race, road, scooter, stock, touch, valve, valves, vtec
