Go Back   Honda-Tech > Honda and Acura Model-Specific Technical Forums > Honda CRX / EF Civic (1988-1991)
Old 06-05-2011, 09:00 AM   #1
big tony's crx
Default Won't go past 3500 rpm
I have a 90 crx -d15b2- 5 speed It's all stock. I haven't changed anything on the car. One day the check engin light came on and now it won't go over 3500 rpms. i've checked everything i can think of. i checked the cat, all the wires, distibator. I can leave the batt. unhooked over night and the light will stay off for about 15 mins. while the light is off it'll rev all the way up. the computer has a little red light on it and it flashes once then 8 times. Can someone help..
big tony's crx is offline   Reply With Quote
Old 06-05-2011, 09:24 AM   #2
big tony's crx
Default Re: Car won't go over 3,500 RPM
It takes a few cranks to start the car. idk where the cranksensor is tho.
Old 06-05-2011, 09:46 AM   #3
eh9_b18cr
1995 Honda Civic
try counting again cause i looked but its not saying anything for code 18.
1 long flash
8 short flash
= 18 does not exist
eh9_b18cr is offline   Reply With Quote
Old 06-05-2011, 10:04 AM   #4
big tony's crx
The light on the computer flashes once then once agin then 8 times.n auto zone dont test past 96 now
Old 06-05-2011, 02:53 PM   #5
turbohatchBnuts
2004 Honda Civic
My Garage
turbohatchBnuts's Avatar
http://www.facebook.com/#!/profile.php?id=100000418839256 or search my name Richard Triplett cptcaveman6883
Default Re: Won't go past 3500 rpm
sounds like to me that you are getting two cels 1 o2 sensor cel and 8 top dead center cel. First i would check and see if the harness wires and ecu pins are getting the right reading using a multimeter. Then if they are you might need new o2 sensor and new dizzy.
turbohatchBnuts is offline   Reply With Quote
Old 06-07-2011, 02:12 AM   #6
BigD4207
I had this same problem on my 91 lx, i changed the fuel filter and gave it some fuel system cleaner and all was good. Just cause you had a cel doesn't mean that's what the problem is, i was flashing 4 or 5 codes with mine, lot of stuff needed changed, but the car ran great after the filter change. At which time i would recommend a tune up, at least the normal plugs/wires/oil.
BigD4207 is offline   Reply With Quote
Old 06-07-2011, 03:35 AM   #7
minimotos95
1989 Honda Civic
minimotos95's Avatar
i believe 3500rpm is around where the secondary injector for DPFI kicks in... it could be something to do with that.
build thread on HCW
WTB: D16 obd0/1 short block in W colo, E utah
minimotos95 is offline   Reply With Quote
Old 06-07-2011, 03:37 AM   #8
BigD4207
Like i said, fuel filter + cleaner might go farther than you think.
3500, accord, car, civic, d15b2, del, dont, honda, past, rev, rmp, rpm, rpms, sol, wont
