Go Back   Honda-Tech > Honda and Acura Technical Forums > Transmission & Drivetrain
Old 06-04-2011, 04:28 AM   #1
mychdb2gsr
1993 Acura Integra
My Garage
mychdb2gsr's Avatar
mychal pollonais
Default Transmission Scraping Noise!! PLEASE HELP!!
I have a 01 ls integra that i recently purchased. The previous owner said his grandson owned the car and acted like an idiot with it. The grandfather had the clutch rebuilt by aamco and bought a used motor from lkq and had it put in by the acura dealership here. I confirmed all of this with receipts. After 2 months of driving the car normally (not taking car above 5k rpm, just driving to and from work, no aggressive driving at all), the transmission is making a scraping noise in first gear and reverse when i let go of the clutch and give it gas. If i push the clutch in the noise stops. It also makes a weird knocking noise in 2-4th gear whenever its at low rpms. Its not difficult to put the car in gear or anything, there's no grinding coming from the tranny, it just makes this weird scraping noise in reverse and first and the knocking noise in the other gears at low rpm. Someone please help me figure this one out. Thanks!!
mychdb2gsr is offline   Reply With Quote
Old 06-04-2011, 08:13 PM   #2
Gearspeed-Performance
Gearspeed-Performance's Avatar
iTrader Rating: (1)
gear.speed.1
Default Re: Transmission Scraping Noise!! PLEASE HELP!!
Sounds like an internal transmission bearing issue. You will have more load in 1st gear and reverse vs. when you are up to speed...so that will explain more of a scrape noise in those gears and knocking at lower speeds in the other gears. I am thinking a bad input shaft bearing. This will require an overhaul of the transmission. While you have your transmission open, check everything else for wear and tear, and change all the main bearings and seals...its cheap insurance. Good luck!
Gearspeed Honda/Acura Tranmission Parts and Performance - www.gearspeedwholesale.com - 909-476-7252
*Rebuild Kits*LSD*Carbon Synchros*Gears*Final Drives*Trans building*
Gearspeed-Performance is offline   Reply With Quote
Old 06-05-2011, 03:03 AM   #3
mychdb2gsr
1993 Acura Integra
My Garage
mychdb2gsr's Avatar
mychal pollonais
thanks james! i guess i'll have to take it back to aamco then! what will end up happening if i continue driving on this issue, if it is what u say?
Old 06-05-2011, 08:56 PM   #4
Mista Bone
D Tranny Guru
Mista Bone's Avatar
Send a message via AIM to Mista Bone
Sounds like ISB (input shaft bearing) to me or they did something really wrong.
Most AAMCO guys only deal with Automatics.
"D" Tranny Guru
Mista Bone is offline   Reply With Quote
Old 06-06-2011, 09:32 AM   #5
mychdb2gsr
1993 Acura Integra
My Garage
mychdb2gsr's Avatar
mychal pollonais
Ok! thanks man, seems like this is what most people think. did a search and seems like the input shaft bearing came alot.
Old 06-06-2011, 11:36 AM   #6
iTrader Rating: (1)
gear.speed.1
Common problem on a lot of Honda/Acura transmissions. We see it a lot.
Old 06-07-2011, 04:15 AM   #7
mychdb2gsr
1993 Acura Integra
My Garage
mychdb2gsr's Avatar
mychal pollonais
Do you know what will end up happening if i continue driving on this issue, if it is the input shaft bearing?
adjustment, bands, bearing, clutch, coming, grind, honda, knock, knocking, low, noise, reverse, single, speed, tech, trandsmission, transmission, weird
