2002 Civic Trunk Wont Stay Closed
Old 06-01-2011, 06:44 AM
116souljah's Avatar
Default 2002 Civic Trunk Wont Stay Closed
My trunk latch does not lock. This is a continuous problem. I've already replaced the latch and after a few months, the problem is back. it is either stuck in lock position or open position but it will not stay closed.
Last night, I used a screwdriver to make sure the latch locks and it does, however, it unlocks with very little force. Can anyone plz help me?
Old 06-01-2011, 08:56 AM
Plead da Fif
It Wasn't Me's Avatar
Default Re: 2002 Civic Trunk Wont Stay Closed
Hmm... have you tried adjusting the striker that the latch attaches to when you close the trunk lid? It's held in place with two 10mm bolts, and is adjustable.
Here, this is a TSB from the FAQ's about the trunk lid being difficult to close. http://www.mediafire.com/?3xtxcjzz1co
SYMPTOM
The trunk lid may be difficult to close or won’t latch
closed.
PROBABLE CAUSE
The trunk lid may be misaligned, and the trunk lid
opener cable, trunk lid latch, lock cylinder, lock rod,
and/or the trunk lid latch striker may need adjustment
or replacement.
Old 06-01-2011, 02:55 PM
116souljah's Avatar
That did the trick. I had done that previously before changing out the latch so I didn't think that it would fix the issue again but it worked. Thanks for your help.
chieromancer
12-08-2015 09:44 AM
xx69xx
07-22-2010 04:18 PM
pinoyboiwonder
09-01-2006 05:33 AM
GuCCi_GSR
09-10-2005 12:43 AM
90-CRXSi
08-17-2002 10:39 PM
Quick Reply: 2002 Civic Trunk Wont Stay Closed
