Old 05-30-2011, 04:10 PM   #1
curtie94
Default Leaking freon
My car 1991 Honda accord is leaking freon, what is the best way to find the leak without refilling it with freon. How much will it cost to find the leak.
curtie94 is offline   Reply With Quote
Old 05-31-2011, 10:54 AM   #2
curtie94
Default Re: Leaking freon
Anyone, I don't think that it has ever been recharged. I did what the manual said, it told me to jump two wired and the compressor kicked on, it says that if it kicks on when you do that that it is low on freon.
Old 05-31-2011, 11:06 AM   #3
chikin pickle
You have to take it to a shop. R-12 is not available. The only reliable way to find small leaks is to charge the system with dye/refrigerant mix. Which will only be available for your system at an a/c place.
Originally Posted by 77777 View Post
damn i think i can get better than 1.9psi if i shove a tube up my *** and attach the other end to the intake and drive around eating burritos.
chikin pickle is offline   Reply With Quote
Old 05-31-2011, 11:44 AM   #4
StreetsideStig
Like chikin said, you'll have to recharge it to find the leak. Most freon recharge kits come with sealant in the can, so you can try that, but you'll have to COMPLETELY evacuate the R-12 before adding any R-134a. If it's a serious leak, you may end up losing alot of new freon in the process of looking for the leak. I would take it to the shop. (I know, I hate taking my '90 LX in, too.)
Streetsideauto.com
Some say that he has trouble getting rid of the rust around his shoulder blades...
...and that he's never learned how to use an automatic transmission...
StreetsideStig is offline   Reply With Quote
Old 05-31-2011, 12:33 PM   #5
chikin pickle
If you add R134a to an R12 system you will destroy the compressor. They use a different type of compressor oil and the two refrigerants ARE NOT compatible.
If you want to do it yourself you must retrofit the entire system to R134a. Not to mention that deliberately discharging refrigerant into the atmosphere is very illegal/irresponsible. Especially R12.
Old 05-31-2011, 07:25 PM   #6
75aces
I took mine to a shop and it turned out that one of the valves was the culprit. Cost me about $140 including freon. Could also be your compressor or clutch. Good luck.
75aces is offline   Reply With Quote
Old 05-31-2011, 07:49 PM   #7
XKINGX
XKINGX's Avatar
I use nitrogen and soapy water.
My vouch thread:::
http://www.hondamarketplace.com/show....php?t=2529610
XKINGX is offline   Reply With Quote
Old 05-31-2011, 09:31 PM   #8
Greg5150
You can still buy R12 on eBay. You need to have an EPA 609 certificate which you can get easily by taking an online test.
Greg5150 is offline   Reply With Quote
1990, 2002, 2006, ac, accord, air, car, conditioner, freon, honda, leak, leaking, leaks, pilot, price, problems, refill, refrigerant
