97 civic ex high beams not working
Old 05-29-2011, 10:02 AM
90, 91 miata's Avatar
Default 97 civic ex high beams not working
i took my new to me 97 ex through a car wash last night, on my way home i went to use the high beams, and they turned a real bright purple and went off. the fuses are good and i have not found the relays yet. i have not checkout the bulbs either, but i don't think they would both burn out at the same time. the low beams still work fine.
Old 05-29-2011, 10:36 AM
vitamin_c95's Avatar
Default Re: 97 civic ex high beams not working
check your bulbs...next weakest link
Old 05-29-2011, 10:46 AM
Linked's Avatar
if the bulbs were damaged, both hi and low beams wouldnt work.
also both sides typically dont go out together if it was a problem with the bulb
its probably raining in indiana though, cause i;m next door in chicago and its pouring down
but the most important thing other than the bulbs is checking if you have voltage at the the connector
Old 05-29-2011, 10:50 AM
i forgot hondas are single bulbs. I actually watched a few bulbs turn purple before blowing. Good point tho
Old 05-29-2011, 11:21 AM
im going to in a few
thats what i thought but idk
its 92 and sunny all week!
thanks i will look into this any one know where the relays are for the head lights? im going to check the voltage befor the relay also.
i have seen that to, but i dont see why they would both do that at the same time.
thanks all i will check them out later and any one know where the relay is for the high beams just so i can rule them out
Old 05-29-2011, 06:02 PM
Former User's Avatar
There's no relay in the circuit.
How did you check the fuses for the high beams? Which fuses did you check?
Old 05-30-2011, 07:58 AM
really?
there are 4 different fuses under the dash two for each high beams and low beams.
Old 05-30-2011, 08:00 AM
Yes, really.
My question is what method did you use to check the two high beam fuses. The most reliable way is to test for voltage to body ground from both top test tabs of each installed fuse with the light switch on. Click the Fuses link in my signature.
Old 05-30-2011, 09:24 AM
the fuses i use are clear and you can see if the are blown or not?
it turned out that the light bulb filament for the high beams burnt out so i will be replacing them later. i have never seen both high beams on a car burn out at the same time before.
Old 05-30-2011, 09:28 AM
Visual inspection of fuses can be unreliable and also does not tell you whether the fuse gets voltage from the battery. But I'm glad to hear that you solved the problem.
Old 05-30-2011, 09:48 AM
thank you, i will check that out
how do you all fill about yellow headlight bulbs in a civic? i know in some cars that don't produce enough light out put bc the way the headlights are made but in some car the work just fine.
Ritchie
11-09-2010 08:46 PM
lastpunkinline
05-29-2008 06:11 PM
darkfx
08-23-2005 07:05 PM
wassup
06-24-2005 04:45 AM
hYpE-R-29
12-29-2004 04:14 PM
Quick Reply: 97 civic ex high beams not working
