Go Back   Honda-Tech > Honda and Acura Technical Forums > Forced Induction
Old 05-28-2011, 01:40 AM   #1
.CUBISH.
.CUBISH.'s Avatar
Send a message via AIM to .CUBISH.
Default Precision 67/65 vs Turbonetics-HPC 64/65 Dyno
I've used both of these turbos on a lot of high HP car but havent had a chance to do both of them back to back.. here is a car that i finished up tonight on relatively low boost..
setup:
84x89 lsvtec
9.5 to 1 compression je pistons
eagle rods
stock port b16 head
stock b16 cams
Victorx intake
open T4 topmount
precsion 750 intercooler
E85
S300
67/65 is journal bearing with a .68 back housing
64/65 is ball bearing with a .81 back housing
both are on 18 psi
Red line= Precision 67/65 journal bearing
Blue line= Turbonetics-HPC 64/65 Ball Bearing
Derf Tuning Facebook
9.93@151 DAILY DRIVER....9.6@160 True Street 825hp Billet 62/65... 08 CBR1000 9.32@152
.CUBISH. is offline   Reply With Quote
Old 05-28-2011, 02:11 AM   #2
SlowReaction
SlowReaction's Avatar
Default Re: Precision 67/65 vs Turbonetics-HPC 64/65 Dyno
Should have used the .81 on both turbos. I believe they are interchangeable? I just picked up one for a customers car, good to see some number since I havent seen anyone else using these.
L*Industries
http://www.facebook.com/home.p...06584
SlowReaction is offline   Reply With Quote
Old 05-28-2011, 02:14 AM   #3
.CUBISH.
.CUBISH.'s Avatar
i did a back to back previously with the 67 with both rear housings...spool was even worse... no point comparing the 64 to that...
Old 05-28-2011, 02:16 AM   #4
.CUBISH.
.CUBISH.'s Avatar
i did a stock bore/stroke b16 back in december with the 64/68. made 800hp on 36psi
Old 05-28-2011, 02:25 AM   #5
SlowReaction
Good to know. Thanks for the comparison. Might have to try one of these 6465 in my own car.
L*Industries
Old 05-28-2011, 06:36 AM   #6
96 GSR-T
1996 Acura Integra
My Garage
96 GSR-T's Avatar
Send a message via AIM to 96 GSR-T
Nice comparison, probably 100whp sitting on the table with a good cam swap, shame such a setup has the most horrible cam available in it.
96 GSR-T is offline   Reply With Quote
Old 05-28-2011, 06:41 AM   #7
ahobbs
HELLO,GOOD MORNIN'
1993 Honda Civic
ahobbs's Avatar
interesting, thanks for the comparison
XBOX:fireahobbs
ahobbs is offline   Reply With Quote
Old 05-28-2011, 06:27 PM   #8
Casey
Casey's Avatar
iTrader Rating: (4)
Send a message via AIM to Casey
nice comparison. what would change at higher hp levels? is this the billet turbonetics? i was trying to find it on their website
Casey is offline   Reply With Quote
Old 05-28-2011, 08:02 PM   #9
.CUBISH.
.CUBISH.'s Avatar
yeah its the billet Turbonetics... hard to say on higher boost levels, but i have made 850hp on the 64 before so i dont see it falling off too much compared to the 67 on higher boost
Old 05-29-2011, 12:52 PM   #10
DelSolMarine
DelSolMarine's Avatar
if the precision was a ball bearing turbo like the turbonetics one that would have made for more of a fair comparison as well... still interesting
84mm 6265 Del Sol 635whp w/ c16 @ 28psi 8600rpm (ran out of fuel)
435whp w/ pump gas @ 13psi (wg) 9400rpm
S&M Auto Built & Matt Shue Tuned
DelSolMarine is offline   Reply With Quote
Old 05-29-2011, 03:06 PM   #11
.CUBISH.
.CUBISH.'s Avatar
a lot of things could have made it more fair... same housings..bb..etc.. but these are the turbos i had. point was to show that the billet 64 is a very capable turbo
115, 6265, 64, 6465, 65, 67, 6765, 68, billet, gt40, highest, hp, hpc, precision, turbonetics
