| Welcome to Honda-Tech! | ||
#1 |
the fat one thats pointing toward front of car it goes down through center of intake manifold piping to a black box....
i noticed this line is colapsing!!! whats this black box and will anything bad happen if i run it colapsed??? |
#2 |
Black box? Do you mean a black drum looking thing that sits on your firewall and has a clear reservoir attached to it? And what do you mean collapsed?
looks like this: http://www.shiftperformance.com.au/i...dc2booster.jpg Some decent grammar wouldnt go astray either...
2001 SY DC2R Limited Edition |
#3 |
i did alittle research and i think its the pcv breather, a fat vacuum line runs to it....
what kind of issues will i have if the lines colapsing? its on back of block under intake mani |
#4 |
its the crankcase ventilation box... if its sucked shut more then likely u need a pcv valve.
#5 |
What happens when the pcv is bad? Symptoms?
#6 |
rough idle/poor fuel and oil consumption
| Tags |
| 1992, black, box, civic, drum, h22, honda, intake, line, lines, main, manifold, real, thing, vacuum, whats |
