> Forced Induction
Old 05-13-2011, 01:20 PM   #1
b16bri
b16bri's Avatar
Send a message via AIM to b16bri
Default bennifits of running no cat
Whats the bennifits or down side of running a cat on a turbo civic vs not running a cat. Sound ? power ?
b16bri is offline   Reply With Quote
Old 05-13-2011, 02:23 PM   #2
Schister66
Man U FTW
Schister66's Avatar
Default Re: bennifits of running no cat
Emissions?
2006 SGM STi
Bullseye Powered 1999 GSR - Sold
Schister66 is offline   Reply With Quote
Old 05-13-2011, 02:27 PM   #3
igorka_91
igorka_91's Avatar
iTrader Rating: (1)
google dot com. have you heard about it lately?
What Are the Benefits of Removing the Catalytic Converters From Cars?
Catalytic converters, which are responsible for igniting and burning unburned engine exhaust gases, became standard automotive equipment on all cars beginning with model year 1975. Although catalytic converters help to make engine exhaust gases cleaner, they are not without their minuses. What follows is a brief list of the potential benefits of removing automotive catalytic converters.
Increased Horsepower
Cars that have their catalytic converters removed experience an increase in engine horsepower. Catalytic converters create a significant source of engine back-pressure due to the constrictive effects they have on exiting engine exhaust gases. Removal of catalytic converters from cars allows exhaust gases to exit their engines much faster and at higher levels.
Better Gas Mileage
Since catalytic converter removal allows for exhaust gases to exit a car's engine at increased speeds, engine back-pressure is reduced, which lessens engine strain. This reduction in engine back-pressure and engine strain enables an engine to work more easily, and thus reduces fuel consumption and increases gas mileage.
Lower Engine Operating Temperature
Since removing a catalytic converter lessens the burden on a car's engine by enabling engine exhaust to vacate the engine more easily, a net effect is a reduction in engine operating temperature. The more easily an engine functions and the less work it has to do results in less friction, less load and, ultimately, a lower operating temperature.
More Fuel Options
Cars equipped with catalytic converters run only on unleaded gasoline. Lead-based gasoline, which produces more power and better engine combustion, quickly destroys the inner catalyst materials of catalytic converters. A car with no catalytic converter will be able to run on a variety of lead-based and/or high-performance fuels that would not be possible with a catalytic converter.
Healthier Exhaust Sound
Catalytic converters operate like car mufflers, whose sole purpose is to muffle the sound of exiting engine exhaust gases. Although catalytic converters burn unburned exhaust gases exiting an engine, thus making tail pipe emissions cleaner, they also further muffle a car's exhaust sound and bestow a somewhat timid, tempered exhaust sound. Without a catalytic converter, a car's exhaust sound becomes a little louder, a little deeper and more distinctive.
5 seconds to look it up.
DD-1996 Integra LS.
Weekend warrior- 2006 Evo 9 2.4L 10.1CR 6765 e85 22psi 552awhp 455awtq
igorka_91 is offline   Reply With Quote
Old 05-13-2011, 11:34 PM   #4
crispchris
crispchris's Avatar
if this is your daily driver i'd strongly recommend against it. You can find good prices on high flow cats that should give you very similar performance gains over the stock cat
crispchris is offline   Reply With Quote
Old 05-14-2011, 08:42 AM   #5
b16bri
b16bri's Avatar
it's not my daily. and on my last set up i had a high flow cat. I was just wondering if the sound would change and how much more horsepower yould be gained running no cat.
Old 05-14-2011, 09:05 AM   #6
pcguy760
pcguy760's Avatar
Xbox 360
I barely noticed a whp gain when I installed a high flow cat. It did make the car sound deeper and louder though..
Turbo Stock Block H22A - 417whp 297tq at 20 psi with water-meth injection Spoolin Performance Traction Bars
Lowe Performance, Alton - IL
pcguy760 is offline   Reply With Quote
2000, car, catalyic, catalytic, catilic, converter, effects, gas, google, integra, louder, mileage, power, removing, running, sound
