<h2b build> Questions
Ok so as of right now i am running a jdm h22 recently dynoed at 214whp/169wtq on Mustang Dyno
-skunk intake mani
-h2b header (swap shop racing)
-just stock ls intake mated with a k&n air filter
-3" electronic exhaust cut out right after header
-92 octain
-evolution h2b kit w/mounts
- gsr tranny (non lsd)
-msd ignition with blaster coil
__________________________________________________ _________________
For my new set up i purchased so far
-skunk 2 pro series cam gears
-crower dual valve springs/titanium retainers
-ARP head studs
-Skunk 2 pro 1s
-O.E.M. Head Gasket
So my question is on the valves im running a bone stock block im not sure wether to by std comp skunk2 valves or high comp ive heard people say that with pro series cams u want high comp valve but im not sure why that is.i dont really understand the whole piston comp thing yet......and also feel free to chim in if u have so suggestions on anything i should add to my list. my goal is around 230-240 whp and between 170-185wtq. am i wishing for to much??
-skunk intake mani
-92 octain
-ARP head studs
-Skunk 2 pro 1s
-O.E.M. Head Gasket
Re: <h2b build> Questions
i just bought sk2 high comp valves, they look just like the stock ones.
im not sure sure either about ur question but will your crower dual valve springs/titanium retainers handle those pro 1s
as far as the springs and retainers holding up i dont know why they wouldnt. the car was street tuned not to long ago just for daily driving and i was curious and took it to a dyno day and it did surprisingly well for runing conservitive timing. it made 221whp & 159wtq but my over all power band increased alot.
ive attached my old dyno sheet to show the gains.
hard to see the numpers but you get an idea of how the power band changed alot.
dyno seem to read very high regardless of what type of dyno it is my cam'd h2b only mabde 196whp but traps 106-107 when gsr/b20v norally make like 190whp and only trap like 100-103
with 221 you should see like 109 trap 12.4s on the 1/4 mile take to the track and see what it runs
im hoping with some seat time this year i will be able to break into the 11s on the bottle. ive been patiently waiting for the track to open up as they have canceled the last two test n tunes due to weather.
maybe im not understanding what u meant by your post?
xxjonxx4
07-23-2017 11:22 AM
JDMAF
02-28-2011 03:49 AM
gsrhatch2356
Texas -OK -LA (Sales)
34
12-24-2010 12:09 AM
