k24a2 vs k20a2
Old 05-03-2011, 04:08 PM
I serve phở for my babies
ohsnapzafingcu's Avatar
Default k24a2 vs k20a2
Obviously the k24a2 has more displacement. Being the bigger motor, is there any disadvantages over running a k24a2 motor vs a k20a2? I understand the stroke is out of the roof and the bore is only a mm larger than the k20. From the VID:
http://www.youtube.com/watch?v=klwOUNb7kSg , the guy makes some monstrous power. Right now i'm not sure if i want to go NA or eventually turbo my setup.
A few questions
1)What'sup with the "06' k24a2's are the best, their cams are larger"? Can anybody elaborate?
2) The 06's are drive by wire from my understanding. To eliminate this can i run an RBC with an aftermarket tb?
3) what other problems will I run into swapping into a 96-00 civic with the k24a2?
I'm having trouble looking for a k20a2 longblock, so i might just wait it out til i find a k24a2. SOooo.. pros and cons of a k24a2?
Old 05-04-2011, 07:50 PM
Default Re: k24a2 vs k20a2
no suggestions?
Old 05-05-2011, 05:34 AM
solo227's Avatar
1. 06 k24 cams are the most aggressive for k24 bottom ends... If ur running a k20... JDM R cams are prolly best for the smaller displacement... Somebody correct me if im wrong...
2. yes RBC and TB will do the job
3. No problems... Should be like another K series swap into a civic chassis
Old 05-05-2011, 06:31 AM
^^ that clears up a little bit. what about the rumor with "cutting an RBC" to make it fit on a k24a2 head?..
Also, To me it seems worth it to save for a k24a2.. Why don't other people....?
Old 05-05-2011, 10:49 AM
solo227's Avatar
I dont know about any cutting... Just do ya research on k20a.org Its been covered a millions times... I dont wanna give u any guesses...
It all depends.. a good k20 frank setup will put out more than a stock k24a2. Those motors usually go for like $1500+ by themselves... So thats why you hardly see people starting their builds with those... Even tho k24s have been getting ALOT more popular over the last 2 years or so...
If u on a budget... I would look into the frank setup cuz they can be extremely cheap(compared to a k24a2) if you look around for great deals... Keep in mind... Most people run Krpo regardless cuz of the options and be able to tune it for another 10-15 hp... For the stock k24a2 u can run a stock ecu... For a hybrid motor Kpro is mandatory...
There are tons of k24 motors around... But you kinda gotta be picky...
K24a1 engine from Honda CRVs will bolt to a k20 head with minimal mods... K24a4 out of the Accord can only be used if you running aftermarket pistons...
You've got options... you just gotta research whats best for you and your budget...
Old 07-14-2011, 03:29 PM
Johnny_Ek's Avatar
video is sick....
Old 07-19-2011, 06:10 PM
egvera89's Avatar
this is good information.
Old 07-24-2011, 04:06 PM
NABeastRR's Avatar
I dont see how your gunna run a k24 on a stock k20 ecu saftly????
there is no cuttin the rbc for k24a2 head its the k20 you have to cut the rbc.
if your looking to throw in the fastest stock motor you can and just enjoy it throw in the k24a2 its like the type R for K series almost.
Old 07-24-2011, 04:10 PM
J.Rod's Avatar
K20a2/k24 frank is the way to go with the right setup it can get up 300hp all motor
Old 09-27-2011, 06:57 PM
STRATTON's Avatar
jose ?
stratton.
Old 11-19-2011, 08:31 PM
ChelseaVayne's Avatar
k20 all the way
Old 11-20-2011, 05:00 PM
usdmftw's Avatar
so many discredit the k24a2 and claim that with k20a2 head its superior. to get 300hp with a k20/24 set up it wont be stock , you would need cam, pistons, head port etc.. i am fairly certain if you was to give the k24a2 this same attn. it would yeild similar results, maybe little less up top maybe more mid range who knows. i do know there has been a couple ppl on k20 running stock k24a2's(stock cams/pistons) and getting 240-250, ovioulsy high end header/exh tuned on kpro and such. just seems not alot of ppl put alot of work into the k24a2 head b/c the k20a2 head out flows it thus deemed the superior head. bottom line is i think the OP would be very happy with k24a2, well any k series really. GL
Old 11-21-2011, 05:01 AM
civicjuna's Avatar
wouw stylé sa, bravo
I have a question:
how you doing the 0 to 100km / h?
you think you just beat a Honda accord type r
Old 11-21-2011, 08:37 AM
Crazy Honda Guy
Deetz's Avatar
This is a North American based site. Nobody here will have the opportunity to find out, they don't sell cars like that here
Old 11-28-2011, 02:24 AM
civicjuna's Avatar
oooh was ok,
thank you for the info
Old 12-22-2011, 04:39 AM
KeseK24RSX's Avatar
K20 vs K24 both w/ the sam mods
K24= RED K20= Blue
We never rec a K20 unless its a turbo app.
-Marquis
-KMOD Performance
Old 12-31-2011, 11:44 PM
onecleaneg's Avatar
i so want to k swap my eg hatch
Old 01-10-2012, 04:44 PM
noz79's Avatar
I got one its pretty quick but theres a thread on here that talks about ground to oil pan height. My oil pan is 2.25" from the ground so before you buy anything research that thread.
Old 01-18-2012, 03:48 PM
moneymaker07893's Avatar
I have a 04 k24a2 motor and I love it compared to the k20. Much more tq just needs the k20 oil pump for the high revs.
Old 01-19-2012, 10:09 AM
Bwill's Avatar
add the RSX VTC mechanism for up to 45 degree of travel and basic bolt ons and you will have a beast.
Need more info on this subject check out the link..http://www.hondata.com/tuning_k24a2_tsx_engine.html
Old 01-19-2012, 12:19 PM
Bwill's Avatar
Whatever you go with be sure and get LSD. On the streets traction will be an issue with either motor.
Old 02-21-2012, 08:47 AM
kteggy88's Avatar
Larger cams tq monster and amazing in a dc shell
Old 02-22-2012, 02:35 PM
streetcreation8's Avatar
nice vid! almost done building my k24
Old 02-08-2013, 05:14 PM
MitchConnor's Avatar
theres a k20a3 65k for sale in social for 500$. i was thinking about doing this swap, i heard that the fuel economy was better.
Old 02-17-2013, 01:37 PM
dc2_4life's Avatar
It might be fun as an upgrade, bang for buck. But unless you plan on forced induction, I would suggest going with the k20a2. No one really builds a3's...
Swap into what car?
Quick Reply: k24a2 vs k20a2
