Old 05-02-2011, 05:56 PM   #1
psychojason
Icon2 how to replace front wheel bearings on 1990 accord
having some issues on finding a diagram or something to go by while taking everything apart
psychojason is offline   Reply With Quote
Old 05-02-2011, 06:02 PM   #2
psychojason
Default Re: how to replace front wheel bearings on 1990 accord
i was told that its hard to take them out... all i know is that they bolt on behind the spendal
Old 05-02-2011, 06:38 PM   #3
xpsychojasonx
1990 Honda Accord
xpsychojasonx's Avatar
xpsychojasonx
Send a message via AIM to xpsychojasonx Send a message via Yahoo to xpsychojasonx
is there anybody that help me out
xpsychojasonx is offline   Reply With Quote
Old 05-02-2011, 11:47 PM   #4
holmesnmanny
autozone has repair manuals for this, or you can simply take off the knuckle and take it down to a machine shop and pay them 20 bucks to press out the hub and bearings for you.
91 Accord w/ H22A swap: Newest update on CARB cert...... Passed smog at the REF...Offically CARB certified !!!
holmesnmanny is online now   Reply With Quote
Old 05-03-2011, 06:09 AM   #5
xpsychojasonx
1990 Honda Accord
xpsychojasonx
does o'reillys have anything
Old 05-03-2011, 06:32 AM   #6
kegobeer
Most auto parts stores sell repair manuals for Honda Accords. When I replaced mine, I just removed the knuckles and let my local Napa shop press out the old ones and press in the new ones.
1997 Honda Accord LX, 125K miles
kegobeer is offline   Reply With Quote
Old 05-03-2011, 07:00 AM   #7
TouringAccord
H-T Order of Merit
TouringAccord's Avatar
Take a look at just about any front brake rotor replacement thread for the 90-97 Accord and you'll see talk about how to get the bearing/rotor/hub assembly apart from the knuckle to replace the font brake rotor. Take a look in the FAQ and use the search function.
basically...
lift and support front of vehicle
remove wheels
remove axle nut
loosen 4 bolts holding rotor to the hub
remove brake caliper
remove castle nut remove lower ball joint
pop lower ball joint free from the control arm to gain room for removing axle
remove axle from hub
put lower ball joint back into control arm
remove 3 bolts from back side of knuckle holding the bearing/rotor/hub assembly to the knuckle
now, if you are lucky the assembly will come apart from the knuckle with a little effort. But more likely than that is the bearing will be rusted into the knuckle and take some force to remove. If you aren't able to remove the bearing/rotor/hub assembly yourself, you can remove the entire knuckle assembly from the car and take it to a machine shop and have them use a press to remove the assembly, remove the hub from the bearing and press the hub into the new bearing. Then I would clean the knuckle up really good, put some anti-seize or grease in the bearing bore to make removal the next time easier, and reassemble everything.
TouringAccord is offline   Reply With Quote
Old 05-03-2011, 09:28 PM   #8
xpsychojasonx
1990 Honda Accord
xpsychojasonx
the wheel bearing on my car bolts on
Old 05-04-2011, 05:17 AM   #9
TouringAccord
H-T Order of Merit
yeah... ???
Old 05-06-2011, 05:36 AM   #10
xpsychojasonx
1990 Honda Accord
xpsychojasonx
so is there any other way of replacing besides taking the spendal off?
Old 05-06-2011, 07:15 AM   #11
TouringAccord
H-T Order of Merit
yes, please re-read my first post...
you may only need to remove the knuckle if the bearing/rotor/hub assembly doesn't want to come out after removing the 3 bolts on the back.
Old 05-06-2011, 12:04 PM   #12
holmesnmanny
Why was the OP banned?
Old 05-06-2011, 12:07 PM   #13
kegobeer
Might have something to do with the fact that the OP and xpsychojasonx are probably the same user.
Old 05-08-2011, 02:43 PM   #14
xpsychojasonx
1990 Honda Accord
xpsychojasonx
yes the OP is my log on through facebook
Old 05-08-2011, 05:36 PM   #15
0FCPImport
Send a message via AIM to FCPImport
If you have any question on the install, we have a daily sales team here consisting of a few certified technicians taking calls all day long. So feel free to give me a call at 1-877-634-0063 (hit prompt for tech advice). Also we just created a new Import site that has wheel bearings and thousands of other parts. Adding more & more parts every day would love some feedback http://www.fcpimport.com/
FCPImport is offline   Reply With Quote
Old 05-09-2011, 07:00 AM   #16
Fabian
check youtube,erick the car guy ,have a nice viedo on this...
Fabian is offline   Reply With Quote
Old 05-10-2011, 12:23 AM   #17
xpsychojasonx
1990 Honda Accord
xpsychojasonx
ok kool, ill have to look it up
1990, 90, 92, accord, assembly, bearing, change, civic, front, honda, lx, press, replacement, video, wheel
