Found this in my IM, name this part!
Re: Found this in my IM, name this part!
It's not a pcv valve, it looks like there's kind of a injector type connector on the top with two wires going threw it to the bottom.
hope its not the intake air temp sensor. How the hell it got sucked in to the manifold ....? Probably fell in during removel of intake tube. Do you have a cai or stock airbox..?
if it is the ia temp . Then that is not your problem... All that will do is cause the fuel mix to be off. Should stay open loop and read off the built in fuel map. The rest of it is probably still in your intake tube or connected to the harness near the throttlebody. Somebody in a rush ?
Seagull Management
Looks to be a foreign object of some sort. Possibly some sort of plug, but I don't believe it's part of the stock intake, I've never seen anything like it before.
wow... Cause i could have swore that IM stood for intake manifold. ........Then he probably forgot to unplug the intake temp sensor when he ripped the cai from the engine. Hence the part in the intake TUBE/PIPE/ARM/ETC. .................................................. .........
The intake mani is on, I found that part looking threw the throttle body. Yes, I can hear the fuel pump priming and the dash lights are on.
GimpyAccord
09-25-2002 12:42 PM
