94 honda civic dx idle problem
Old 04-26-2011, 10:23 AM
mattf22b1's Avatar
Default 94 honda civic dx idle problem
I'm having problems with my car when stopping or just letting it sit there and idle. Ive checked the electrics and there good, the previous owner put a short ram on and decided to take out the carburetor filter out so i have replaced that and covered a small gap in the top of the carburetor. Any ideas on what else it could be? And does anyone know where the idle control valve is located on this model? engine code is d13b2..ive also checked the short ram and cleaned the air filter for that aswell.
Old 04-26-2011, 10:30 AM
DeLSoLRo's Avatar
Default Re: 94 honda civic dx idle problem
you forgot to state what your problem is.
Old 04-26-2011, 10:37 AM
mattf22b1's Avatar
Duh so i was on the phone when i typed this my car keeps stalling because the revs are too low..and its not bouncing it idles at around 4-500 rpms
Old 04-26-2011, 10:48 AM
DeLSoLRo's Avatar
unplug the tps sensor and try raising the idle screw (gold screw) on the throttle body
Old 04-26-2011, 11:07 AM
frankenghia's Avatar
94 is fuel injected so the part you are talking about is a throttle body and don't unplug the tps to adjust the idle. Unplug the IACV and then adjust the idle.
Old 04-26-2011, 12:14 PM
mattf22b1's Avatar
not all 94's were fuel injected and mine is definitely carbureted..is there an idle control valve as there is no intake manifold?
Old 04-26-2011, 01:48 PM
mattf22b1's Avatar
Heres a picture of my engine..where would the icv be if i have one? What else can i do to change my idle and clean out the intake system.
Old 04-26-2011, 02:05 PM
HOLLY CRAP!!!!!!! Never seen a 94 carbed.... It must be some sort of relic...lol... I don't think a carb would have an IACV... Have you checked your float level? Fuel filter?
Old 04-26-2011, 02:07 PM
also have you tried to adjust the idle? Should be pretty simple on a carb. I think it is just the throttle stop screw if I am not mistaken. Not completly sure about honda carbs but all other carbs I have seen adjust this way...
Old 04-26-2011, 03:32 PM
hmonguy918's Avatar
looks like crx dx motor
Old 04-27-2011, 10:08 AM
mattf22b1's Avatar
i changed the fuel filter today and still no change. Is the idle adjusting screw underneath the carb? I downloaded the manual and it seem like thats where there pointing to but i dont want to take it of if im reading the directions wrong
Old 04-27-2011, 11:06 AM
lunareg's Avatar
oh your in england.. yeah the carbed civics only came out in euro market.
Old 05-03-2014, 10:03 PM
j40987's Avatar
First off, hello. I'm new to the forum. Second, I'm sorry for reviving this thread, but in the image provided of a carb'd d13, what is that part on the upper left hand side of the engine valve cover with a red hose running towards the carb? Is that the fuel filter? I have a similar motor and was wondering If I could identify the piece before unplugging the hoses.
Old 05-04-2014, 01:26 AM
j40987's Avatar
Nvm. Apparently that's a mechanical fuel pump! Anyone have ideas on how to check if it's still good?
titan12
01-03-2015 03:34 PM
Kaliona
13
09-04-2014 06:12 AM
BACKWOODSTEG
09-10-2005 10:08 PM
toyzbus
03-15-2005 11:55 AM
CRX-SIR
09-20-2004 06:00 PM
Quick Reply: 94 honda civic dx idle problem
