Go Back   Honda-Tech > Honda and Acura Model-Specific Technical Forums > Honda Prelude
Old 04-22-2011, 08:38 PM   #1
doristilton
Default How many miles can you expect a Honda Prelude to last for?
Would buying a one owner, all stock 2000 Honda Prelude with 110,000 miles be a bad move. It's a five speed and has been taken care of. I can get it for $5000.
doristilton is offline   Reply With Quote
Old 04-22-2011, 11:47 PM   #2
InvaderTrax
InvaderTrax's Avatar
Send a message via AIM to InvaderTrax
Default Re: How many miles can you expect a Honda Prelude to last for?
Do it. If the timing belt hasn't been done, do that too
Originally Posted by v8h8 View Post
Cool build! I cant really tell what is what from the pictures. I also like the fact that you have a KNN air filter, those are a must!!! Just swap for a V-TECH head and youll be set!
InvaderTrax is offline   Reply With Quote
Old 04-22-2011, 11:51 PM   #3
KrazyLuEg8
KrazyLuEg8's Avatar
Send a message via AIM to KrazyLuEg8
How bout a 98 with 230k Bone stock
KrazyLuEg8 is offline   Reply With Quote
Old 04-22-2011, 11:56 PM   #4
crxlover5273
do either. hondas are way reliable.
crxlover5273 is offline   Reply With Quote
Old 04-23-2011, 05:58 AM   #5
godslayer
2000 Honda Prelude
godslayer's Avatar
I own a 2000 Honda Prelude with a factory 5-speed and about 110,000 miles on it. It was a single owner car with about 40,000 miles on it when I found it. Here's what I've had to do to my car since buying it 5 years ago.
Minor/Preventative maintenance:
Brakes
Timing/Drive belts
Oil changes
Tires
Coolant flush
Valve lash adjustment
Major:
Transmission @ 88,000 miles (5th gear & reverse locked out)
Clutch & cylinders (only because I had the tranny out already)
Limited Slip Differential (only because I had the tranny out already)
One rear bearing/hub
Two upper control arms/ball joints
Needs:
Suspension (starting to feel loose)
Some minor rust spots on the hood from rock chips & such
Overall it's been a good reliable car in the time I've owned it and I try to keep up on the maintenance. A car taken better, or worse, care of may differ dramatically.
Frank Corona
godslayer is offline   Reply With Quote
Old 04-23-2011, 06:54 AM   #6
Confessed
Confessed's Avatar
Send a message via AIM to Confessed
I have a 94 S with 200k+...lol. Completely stock and runs strong(obviously had some repairs over time).
Confessed is offline   Reply With Quote
Old 04-23-2011, 09:12 AM   #7
Thickback
I bought a 1997 Prelude with 255,000 for 3Gs....(I needed a car bad, my Avalanche is killing me on gas and my 95 accord is sick....)
So far, besides burning a lil oil, the car runs great. The previous owner took excellent care of it, had all repair records and had it painted in the last few years. Even if the engine goes, I love the car and plan on modifying it any way.
Thickback is offline   Reply With Quote
Old 04-23-2011, 10:44 AM   #8
wh1teredneck
2001 Honda Prelude
My Garage
wh1teredneck's Avatar
Send a message via AIM to wh1teredneck
Two years ago I bought a 1998 Prelude Type SH with 154,000 miles. 1 previous owner from North Carolina. I found it listed online for $6000 and took it for $5000. Now it has 176,000 miles its my daily drive and I run it hard! I havent had any major problems. Only major thing was that the crank shaft pulley broke and had to replace it. So i decided to add performance clutch and flywheel. Runs great! Im thinking about doing a rebuild though just because I want the fullest power from the engine, later going on boost!
wh1teredneck is offline   Reply With Quote
Old 04-24-2011, 06:52 AM   #9
Mr. Prelude
1990 Honda Prelude
They run great if you treat them well. Oil changes and check your timing belt time to time!
Mr. Prelude is offline   Reply With Quote
Old 04-24-2011, 06:18 PM   #10
mike541
mike541's Avatar
I know it's not a Prelude, but never the less... a lady brought her old civic into the shop the other day with 330,000 miles on it. One owner all miles on same motor. Said she had it serviced regularly and it still ran strong and didn't burn much oil at all.
All depends on how the owner drove the car and cared for it.
mike541 is offline   Reply With Quote
Old 04-24-2011, 08:01 PM   #11
Confessed
Confessed's Avatar
I've never seen any ride with over 300k...that's so much. Highest I've seen is ~280k or so on early 90's work trucks.
Old 04-24-2011, 09:11 PM   #12
Luded93
Luded93's Avatar
iTrader Rating: (1)
Send a message via AIM to Luded93
I bought a 90 Prelude Si with 2 previous owners and 116,000 miles on it 7 years ago for $600. Aside from maintenance and a new exhaust the thing runs great. Leaks a little oil from a bad cam seal but it does not burn any. As everyone is saying, if a car is cared for, it can last for a very long time.
Going to school does not make a person educated any more than going to a garage makes a person a car
FS: H22a1 Skunk2 Head http://hondamarketplace.com/showthread.php?t=2920486
Luded93 is offline   Reply With Quote
Old 04-24-2011, 10:15 PM   #13
mike541
mike541's Avatar
I've now seen two.. one was a Toyota truck, mid 80's. And the other was this Civic. I honestly didn't believe the lady until I looked myself.
Old 04-26-2011, 11:02 AM   #14
Phan10ms
Send a message via AIM to Phan10ms
I'm at 177k and it's still running strong. 99 Base prelude.
Phan10ms is offline   Reply With Quote
Old 04-27-2011, 12:41 PM   #15
Prelude01h22
I owned 5 hondas and one was a 83 civic with 220,000 miles on it when I sold it. I also owned a 88 prelude with 277,000 miles on it when I bought it and the speedometer and miles didn't work so it probably had over 300,000 miles on it. Now I own a 01 prelude that has a 110,000 miles and it run strong still and I beat it like a ex wife. I will never buy any other type of car hondas our very relaible and they don't lose value.
Prelude01h22 is offline   Reply With Quote
Old 04-27-2011, 08:58 PM   #16
Sanova
Sanova's Avatar
Send a message via AIM to Sanova
Had mine for well over 250,000 before I sold it, and its still out there running today
Sanova is offline   Reply With Quote
Old 04-28-2011, 05:55 AM   #17
typemismatch
Honda owns me
typemismatch's Avatar
Mine's a 92 on motor 3, swapped SOHC F22A out for JDM H22, the F22 was still running strong when I pulled it.
Something weird happened when I tried to start the H22 over the winter in -30 degree weather and it's never run right since, so I'm building a turbo H22 now. I wouldn't consider this a failure of the motor, I would consider it a failure of the owner.
The actual chassis has 127K on it. My experience with Prelude and Honda reliability in general is that if you fix the problems it has when you get it and maintain it properly, you'll almost never have a real problem. And don't do stupid things to it like start it in -30 weather.
I've also had:
90 Civic Ex 4 door - traded in on 04 Civic Si 220K
91 CRX Si D15, then B18A swapped - 188K
93 Civic Ex D16 - hit by an SUV while parked - 183K - sold and still driving around town
95 Civic Ex D16 - went with the ex gf - over 200K when it finally died, due to neglegence
04 Civic Si K20 - traded in on 07 Si - 36K
07 Civic Si K20 - Current DD - 45K
1992 Prelude S - 469hp/340tq@15psi - 12.46@117mph
2007 Civic Si - FG2 - almost stock (DD)
92 EG H2B - build thread http://www.honda-tech.com/showthread.php?t=2944704
typemismatch is offline   Reply With Quote
Old 04-28-2011, 02:40 PM   #18
blackedEk
blackedEk's Avatar
^agreed
blackedEk is offline   Reply With Quote
Old 05-01-2011, 05:39 PM   #19
stu_bb2
1992 Honda Prelude
stu_bb2's Avatar
stwar.fernandez stwar9
true that
stu_bb2 is offline   Reply With Quote
Old 05-01-2011, 05:56 PM   #20
Yuyodrift91
Yuyodrift91's Avatar
Send a message via AIM to Yuyodrift91
What kind of question is this???
It's a HONDA. No duh it's going to last...
1992 Prelude BA8, 1995 Prelude BB2 *SOLD*, 1995 Prelude BB2, 1999 Prelude BB6
Yuyodrift91 is offline   Reply With Quote
Old 05-01-2011, 07:29 PM   #21
jaggin23
my 99 type sh has 114,000 on it and people think it's a brand new car. take care of it and it will be good to you.
jaggin23 is offline   Reply With Quote
Old 05-06-2011, 05:51 AM   #22
balliso911
balliso911's Avatar
ive got a 93 vtec with original motor currently at 261xxx. Still runs strong. I have a h22a4 which was completely rebuilt sitting in my garage, im waiting for this motor to die so i can put the new one in.
balliso911 is offline   Reply With Quote
Old 05-08-2011, 09:47 AM   #23
samson_420
I just tore down a motor from a 92 Prelude we bought. 267k+ the last owner was obviously a total tard. The car is beat, the motor got hot and snapped the cam. Crank looks new, you can still see most of the honning and the bearings have plenty of life left.
If this car was somewhat taken care of I think this motor could have seen 300+ with ease.
samson_420 is offline   Reply With Quote
1992, 1997, 98, expect, good, h22, honda, last, miles, pilot, prelude, preludes, put, run, si
