Old 04-22-2011, 10:33 AM   #1
Dekorum
Default Bumper to fender bolt/screw
Does any body know any tricks to get the plastic grommet to stay in the fender so you can use the OEM phillips screw to hold the bumper to the fender?
The plastic grommet I am talking about is number 11 in this picture
My driver side fender was using some crappy metal bracket which rattled and didn't hold the bumper on close enough to the fender. So I bought a new plastic grommet/screw so I could put it the bumper on the OEM way like the passenger side, but I can't get the plastic grommet to stay in the hole.
Dekorum is offline   Reply With Quote
Old 04-22-2011, 10:43 AM   #2
rick_rabies
I'm not Rick!
1994 Honda Civic
rick_rabies's Avatar
Default Re: Bumper to fender bolt/screw
superglue.
epoxy.
jbweld.
An armed society is a polite society *2nd amndmnt*
"if you have a cloak, and if you don't have a sword, sell your cloak and buy one. Luke 22:36KING of kings
rick_rabies is offline   Reply With Quote
Old 04-22-2011, 01:30 PM   #3
Dekorum
Anything else? I don't want to jump into putting superglue on my fender unless its my last option.
Old 04-22-2011, 01:35 PM   #4
grumblemarc
The Grumpiest
1996 Honda Civic
grumblemarc's Avatar
iTrader Rating: (3)
Send a message via AIM to grumblemarc Send a message via Yahoo to grumblemarc Send a message via Skype™ to grumblemarc
With that piece on the front it kept popping out so I zip-tied it until I could figure out something better. Didn't like having to do it but 2 of them hold on pretty well and isn't permanent.
FAQs!--How to Turbocharge your Civic--Want a faster Civic?--DIYs
Originally Posted by wantboost View Post
I wish more parents would beat their children, then maybe most of them wouldn't be total spoiled, self absorbed *********.
grumblemarc is online now   Reply With Quote
Old 04-22-2011, 03:50 PM   #5
TwoFaced
2000 Honda Civic
TwoFaced's Avatar
^x2
Originally Posted by the comanche View Post
Let's see some dicks!
TwoFaced is offline   Reply With Quote
Old 04-22-2011, 03:53 PM   #6
lunareg
1993 Honda Civic
My Garage
lunareg's Avatar
lol I came in here to see what part it was too, my bumper is zipped tied on one side. it works obviously, but its not really lined up right lol
boosted zc
lunareg is offline   Reply With Quote
Old 04-22-2011, 04:46 PM   #7
civicsmoke
civicsmoke's Avatar
make sure the lip on the fender is flush with the bumper, then get yourself some stainless steel bolts and nuts, use washers on both sides.
civicsmoke is offline   Reply With Quote
Old 04-22-2011, 05:06 PM   #8
HaZyEk9
HaZyEk9's Avatar
^x3
I have basically my whole front end zip tied and you arent even able to tell the diffference. Get the heavy duty black ones with the metal lock and youll be good!!! Dont use the cheap white ones you can see and they arent as durable. Atleast until you figure what else to do,but ull prolly end up leaving it! Human instict
HaZyEk9 is offline   Reply With Quote
Old 04-23-2011, 12:17 AM   #9
s13hero
s13hero's Avatar
This is what I did too.
95 DX Hatch-All stock D15B7
s13hero is offline   Reply With Quote
Old 04-23-2011, 09:00 AM   #10
Dekorum
You used an actual nut? Thats kind of hard to have to hold that with a wrench while you are tightening the bolt, since the area is pretty tight to work in. Most people use the metal bracket with the nut welded onto the back, like in the OEM lip hardware kit.
Old 04-23-2011, 09:14 AM   #11
EJ1civic coupe
EJ1civic coupe's Avatar
Send a message via ICQ to EJ1civic coupe Send a message via AIM to EJ1civic coupe
then if you dont wanna do that option then why dont you buy the OEM hardware kit..duh
theres so many options out there on what to do..the little white plastic peice isnt gonna last for ever..mine eventully started coming out as well and all i did was use the nut and bolt option..its not hard at all to get in there and tighten it up if you kno what your doing
EJ1civic coupe is offline   Reply With Quote
Old 04-23-2011, 09:17 AM   #12
lunareg
1993 Honda Civic
My Garage
lunareg's Avatar
yeah if you take the corner light out, its easy as hell to get at it.. I just went for the zip tie since its easy to cut it out if you need to get your bumper off, lol
boosted zc
Old 04-23-2011, 09:18 AM   #13
Dekorum
Ok, cool. Just trying to see some ideas as to what others are doing.
Old 04-23-2011, 09:52 AM   #14
EJ1civic coupe
also turn the wheel inwards so you can get more leverage if you wanna use bolts/nuts..and zip ties are easy as hell to..5 screws up top..2 bolts on bottom and 2 snips on the sides and there you go the bumper is off less then 3 mins
Old 04-23-2011, 02:44 PM   #15
sde780
sde780's Avatar
Send a message via AIM to sde780
The more you screw the screw in, the better the plastic clip holds. Might want to make sure the fender tab that it goes in isn't bent. If it is, bend it back
2012 Tacoma DCLB
https://www.youtube.com/user/shengdama?feature=mhee
sde780 is offline   Reply With Quote
Old 04-23-2011, 02:55 PM   #16
Dekorum
Yeah thats one of my problems. My fender tab is so mangled. Its just just a staight tab thats bent down. Bending it back still leaves it almost like a piece of paper that was once crumbled. I can't figure out how to straighten it completely since I only have a needle nose plier.
Old 04-23-2011, 03:45 PM   #17
Dekorum
To get an idea of what I'm talking about...
Good side
Bad side
Old 04-23-2011, 03:55 PM   #18
C4_Gsr_civic
1994 Honda Civic
Geeze does evrybody use zip ties? i have them too lol
C4_Gsr_civic is offline   Reply With Quote
Old 04-23-2011, 05:24 PM   #19
sde780
sde780's Avatar
Just use a ziptie. I used a huge plier that exhaust shops use and got mine somewhat straight, but it still wanted to pop out with my fiberglass bumper
2012 Tacoma DCLB
1992, bolt, bolts, bumper, bumpers, civic, dont, fender, hold, honda, kind, line, metal, side, size, tie, zip
