Classic Hondas All Pre-1988 Hondas.
87 CRX idle issue
Old 04-19-2011, 03:48 PM
rsfire's Avatar
Default 87 CRX idle issue
Hi, I have an 87 CRX dx. Is this the section I should be in? I didn't see a place for crx's before 88.
Anyway this is my first carb car, I've had lots of efi toyotas and a mazda. So i don't know much about carbs yet. Not every time but a lot of times i let off the throttle slowing down for a stop or anything the car will die. I have to keep on the throttle and brakes at the same time to keep it running.
Do anyone have any ideas what it could be? I've done a full tune up. NGK-R plugs, new plug wires, oil change, and some other misc stuff. I don't believe I changed the cap and rotor though, they did look pretty good when I pulled them off. thanks for the help!
Old 04-19-2011, 06:25 PM
BenQJDM's Avatar
Default Re: 87 CRX idle issue
it sounds like a carb problem for sure. is it the original one?
Old 04-19-2011, 08:07 PM
rsfire's Avatar
yeah I would guess it is. The car has 213xxx miles. not positive if it is all original. But seems like it is, and it was pretty nicely maintained from what i can tell.
Old 04-20-2011, 05:00 AM
crxguy406's Avatar
My friend... you have wandered into the wonderful world of carb'ed crx's. I've been tinkering with mine for the 5+ years I've owned it, and they will always be fussy to some extent.
I'm not saying you can't get it running good, just that it will always be fussy.
A good start would be to check all your vacuum lines. With your car running, get a can of wd-40 and spray around all your lines. If you hear a change in your idle when you spray a certain line... replace it.
Old 04-20-2011, 06:30 PM
78CITYTURBO's Avatar
Cool tip Crxgut. My 86 Civic SI idles up and down sometimes like crazy.
scarney
01-14-2013 07:14 PM
crxfornow2
02-15-2007 10:43 AM
crex23
05-03-2005 11:01 PM
hondacru27
01-26-2004 10:48 AM
Quick Reply: 87 CRX idle issue
