| Welcome to Honda-Tech! | ||
#1 |
2004 Honda S2000My Garage |
EDIT:
Fuse 43 was blown under the hood. Its a 7.5 amp. My EM1 dome light is shorting it out I dont know why. ANYWAYS, these are the codes I pulled. P0113 Intake Air Temperature (IAT) Sensor Circuit High Voltage SWAPPED IATS AND FIXED THE PROBLEM. JK [b]Primary Heated Oxygen Sensor (Primary HO2S) (Sensor 1) Circuit Low Voltage[/b JK [b]Primary Heated Oxygen Sensor (Primary HO2S) (Sensor 1) Circuit High Voltage[/b JK [b]Manifold Absolute Pressure (MAP) Sensor Circuit Higher Than Expected[/b 1. Does code 113 with the IAT mean that the IAT sensor is bad? I believe I have a spare. 2. How does the primary o2 read high AND low?? That doesnt make sense. 3. MAP circuit higher than expected?? Do I also need to replace the map? Sup all 1999 Civic Dx OE engine (mod wise) OE P2E ECU I got state ref'd in CA so I went back to stock. I took off the P28 and threw on the P2E ECU that I bought on craigslist from a wrecked car. The car turned on first try and everythings fine. Only problem is; its running a little rich (smells like it has no cat, but it has the factory one.), and when I connect a scanner to it, the scanner doesnt read. I took it to Pep Boys for them to scan and they couldnt scan either. The scanner doesnt even turn on so I dont think the OBDII port is getting power. I looked around and I dont see a fuse for the port. Is there a fuse somewhere else around the car? Im in Texas right now but I need to go back to California to fix this ticket.
2003 Honda S2000 Sebring silver (RIP) 2004 Honda S2000 Nighthawk black pearl (current) |YOU DON'T NEED A CAMBER KIT, YOU NEED AN ALIGNMENT| Last edited by Arthas; 04-19-2011 at 07:07 PM. |
#2 |
Moderator
2000 Honda CivicMy Garage |
Hood fuse 43
Don't guess, troubleshoot --------------------------------------------------------- Useful tech links: FAQs; Codes; Check Spark; Test Fuses; Fuse 15 TSB; Clean IACV or FITV --------------------------------------------------------- Please don't PM me tech questions. Create a thread. |
#3 |
Which fuse is that? The under hood fuse box isnt labeled by numbers.
Its not the F/I EM fuse is it?
2003 Honda S2000 Sebring silver (RIP) 2004 Honda S2000 Nighthawk black pearl (current) |YOU DON'T NEED A CAMBER KIT, YOU NEED AN ALIGNMENT| |
#4 | ||
Moderator
#5 |
Ron, you are amazing with Hondas and I would love to buy you a beer. I just relocated to San Antonio, TX! haha
Can you change the thread title to: "Codes P0113, P0131, PO132, and P1129; High and low voltage on same O2?"
#6 |
Moderator
Title changed. Start by resetting the ECU to see whether all codes return.
#7 |
Appreciate that.
And done.. Only code P0113 returned. I tried deleting it and after 2 seconds it returned. Something tells me I forgot to reset my ECU when I installed the O2 sensors and I drove rich all the way to TX from CA. fuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuu
#8 |
Moderator
Inspect the IAT sensor and its connector and wires. Is it unplugged?
#9 | |
![]() ![]() You 'da best man. You have no idea how much I appreciate it.
#10 |
Moderator
#11 |
P0131 and P0505 came on after about 20 minutes of driving.
FML.
| Tags |
| 1999, 2000, 97, 99, accord, cel, civic, dx, fuse, honda, link, p0113, rich, running, scan, smell |
