F! How do you remove the F!ing wiper arm?! :(
Ah man, first i have my Fit's rear wiper arm stuck, now i am trying to remove my driver side wiper arm on my Integra and is stuck as well!!! I can't fit anything under it to pry it out or anything. Do any of you experts out there have a trick or 2 to remove the wiper arm? WD40 (no PB blaster here)currently being soak... Passenger side arm cam out like butter...
Re: F! How do you remove the F!ing wiper arm?! :(
If only it was that easy. So far,
- i tried hitting the side of the arm near the stud (trying to break it loose some how).
- pulling the arm up and use a hammer to hit the stud
- used a electric wire, wrap around the arm near the stud and yank it hard
any tips would be appreciated...
hum... this one i guess
http://www.amazon.com/Lisle-54150-Ba.../dp/B000I14RY6
I guess i have no choice but to grab one.
50:50 Mix of automatic tranny fluid and acetone (nail polish remover) is the best thing for removing stuck bolts and what not. Sounds weird, but it really works. Try some of that and see if it'll help you out, Sounds like someone forced the wrong arm on in the first place.
on the back wiper remove the plastics on the hatch unhook the harness then on the wiper there will be a cover pop it off then i think its a 10 mm unscrew the nut and slide out the wiper acura makes a delete plug for that hole roughly 15$ from the dealer
So i've returned the wiper puller, and got my 36$ back since it didn't fit in at all. I need to find a super narrow, small puller now...
Old Fart
This is the one I have... http://www.sears.com/shc/s/p_10153_12605_00971054000P it has worked on everything I needed it for so far. 94
And for everyone else who said "wiggles it"... don't bother posting please... As i said, i got the passenger side off easily.
TOO MUCH TORQUE
Northern California (Sales)
01-29-2016 06:15 PM
jash
16
07-12-2010 03:55 AM
