Whats the most horsepower you can get from an all motor B18c5?
Old 04-21-2011, 06:00 AM
  #26
rhd_integra_r's Avatar
Default Re: Whats the most horsepower you can get from an all motor B18c5?
Originally Posted by Tonio
Why?
OP
It takes a substantial amount of money to get anywhere near 250whp. That's what most off-the-shelf B series motors are making at this point 84x89 or bigger. It's tough to make N/A horsepower.
Because its a waste of a perfectly set up platform. There are many other b-series motors that you can use to get what your looking for, give someone else the B18C5 and go buy and LS. I would do the cams, pistons, etc. for reliable power, I would spend the extra $$$. I have had a turboed B18B1 its fun, too much torque even with an LSD, it was only a straight line car. If money is an issue dont bother building any project, you get what you pay for, I spent 5k building my turbo setup from a garrett Gt25r bb turbo, tial bov, hondata s300, trans build, rc injectors, etc. I got the LS to 276WHP... My 2 cents...
Old 04-21-2011, 01:08 PM
  #27
EJ8_Man's Avatar
When does a B18C5 stop being a B18C5? Once its bored to 2 liters, new pistons, cams, valves, springs, rods, crank I don't consider it a B18C5 anymore. B18C5 is a reference to the stock motor with stock internals. I stopped referring to mine as a type R a while ago...
Old 04-23-2011, 05:48 PM
  #28
(. )( .)'s Avatar
Originally Posted by rhd_integra_r
Never boost a b18c5, all N/A set of cams/springs/retainers/valves... should be plenty for a DD car, o yea and a fluidampner... bring the redline up and get a good tune...
even though ive seen alot of boosted c5 builds, i agree. the engine works fine as is, a mild NA build just adds fuel to the fire!
Old 04-23-2011, 09:01 PM
  #29
racebum's Avatar
why? it's still a b18c block, they are all p72 castings and all the same thing.
you can change all you want and still have an itr block
Old 04-23-2011, 09:46 PM
  #30
4DRDB8GSR's Avatar
Originally Posted by itr#1334
I paid 11k and I gots 171 hp at the wheels
yup im about $10-11k into my 81.5x84.5 destroker C5 motor as well. I'm expecting something close to your numbers when i tune this coming up week. Really, ill be happy with anything above 176whp from my 1.76L B18C5/PR3-4.
Originally Posted by mafia
I got over 6K in my motor and its still at 0hp.
Hahahaha thats where i have been for months now, waiting on machine shops, waiting on custom CP pistons, waiting on camshafts, etc etc however as of now my C5 is also making 0hp LoL
Old 04-23-2011, 11:19 PM
  #31
cibao2ner's Avatar
why destroke the b18c? for more rpm?
Old 04-24-2011, 01:20 AM
  #32
S2kRyan's Avatar
Are these $10k+ N/A builds for power in the first place? If so you guys need to find yourself a new tuner...
Old 04-24-2011, 01:26 AM
  #33
4DRDB8GSR's Avatar
Exactly my goal was safe RPM well over 10k so i needed a higher Rod/Stroke Ratio, with a 84.5mm stroke i was able to fit 140mm rods vs the stock 137.9mm rods with the 87.2mm stroke the shorter stroke relieves side wall stress and makes the rods/pistons sit down straighter in the cylinder.
Old 04-24-2011, 01:27 AM
  #34
S2kRyan's Avatar
Originally Posted by Just a n00b
I guess what he could do after I/H/E is get a lighter flywheel and an ATS 4.9 f/d. The acceleration from the quicker f/d could be what he is looking for. I know I want to get a JDM 4.7 in my trans, but I'm not gunna get one until I need to fix something else in my transmission.
I agree with this completley. Ever since my S2000 days I have been a HUGE fan of gearing on hondas. It is by far the best bang for your buck and doesn't sacrifice reliability at all. However, this isn't what the OP was asking about, although the higher final drive will free up gobbs of torque to the wheels. Nothing like a nice set of light wheels and a higher tooth count FD to get the most out of your current motor setup.
Old 04-24-2011, 01:33 AM
  #35
S2kRyan's Avatar
What is the point of taking away the little but of torque you do have and moving the redline up so high? What cams will you be using that you expect to make power above 10k rpms and only put down 175whp? I'm sorry but if you could explain the reasoning for your build a little better, it doesn't make much sense... Why rev so high and not make any power? Or are you just doing it to say you rev over 10k rpms?
Also, IIRC, the RP Racing ITR only reved to 9800 rpm and made 250+ out of a 2.0L block. It did have a Skunk 2 CNC head and all the other bells and whistles.
If you are doing this build for some kind of road racing reason, then you could have saved yourself $9000.00 and just purchased a 4.7 or 4.9 FD and made more torque and been ALOT faster around a road course than sitting at 9-10k rpm trying to pull out of turns. Torque is what pulls you out of turns.
Old 04-24-2011, 05:15 AM
  #36
H-PIMP's Avatar
Reliable, 100K mile daily driveable, 210whp is realistic. Built, tuned, and, maintained properly.
240-250whp is possible without going 2.0, but the life expectancy will be way down. High compression, high revving, high hp n/a B series aren't really known for their life expectancy.
Old 02-14-2013, 02:26 PM
  #37
Freezen's Avatar
lol ^^^ My jdm b18c type r made 194whp untuned hahaha
Old 02-14-2013, 02:48 PM
  #38
GagnarTheUnruly's Avatar
Old 02-14-2013, 03:33 PM
  #39
1998GsRIntegra's Avatar
Old 02-14-2013, 06:30 PM
  #40
gwarfare's Avatar
Yea seems kinda odd i had a b18c5 in 04 and we had it at 227hp for 3years and was a 5k bulid just keep it simple those motors can take a beating if bulit right and has a great tune plus u can tune a stock ecu and still make power. Yea it depends on the tunner and builder and just do a lot of research.
Old 02-16-2013, 11:49 AM
  #41
dpt79606's Avatar
x2
i have the 4.9fd in my R and it makes a nice difference over someone who doesnt have one. Awesome upgrade if you ask me.
Old 02-16-2013, 12:51 PM
  #42
racebum's Avatar
how exactly does tuning a stock ecu work? no one makes support for obd2a or obd2b
Old 02-17-2013, 10:32 AM
  #43
HYREV2NR's Avatar
More than likely referring to a VAFC which I am not a huge fan of being Hondata is the way to do it correctly.
Old 02-17-2013, 11:57 AM
  #44
racebum's Avatar
oh lordy, a vafc can comp for minor mods but they have a very narrow window of change. you can't change the injectors or really even cams well. all one of those does is jump in front of the factory signal. you also can't change ignition tables
Old 02-20-2013, 08:03 AM
  #45
HYREV2NR's Avatar
^^^Yeah and I remember when a VAFC and a re-chipped ECU was the only way to go. Thanks God for S300.
Old 02-20-2013, 11:27 AM
  #46
I said I don't want a title!
Todd00's Avatar
You bumped a 2 year old thread just to post this?
Old 02-20-2013, 08:49 PM
  #47
kyosoeg6's Avatar
the cheapest way to make the most tq/hp is to do a nice kswap.
my stock tsx motor puts out more tq than a fully built streetable c5 motor will ever get you.
Old 02-21-2013, 09:18 PM
  #48
gwarfare's Avatar
Well anything these day can be tune,plus a kswap is ok,not the best for dd,seen a lot of kswaps go bad after 30k. Seen b18c5 last years if "bulit right" do what u want but now chp in Cali is starting to crack down on kswaps and the state ref is getting tougher to pass? Was just there with a buddy of mine doing his kswap to pass and it failed visual inspection,he has droped well over 15k with swap to pass legit and they said no.
Old 02-21-2013, 11:11 PM
  #49
blacK_Dc4's Avatar
lol a stock longblock? otherwise, i highly recommend tuning it.
Old 02-21-2013, 11:16 PM
  #50
Tkrizz's Avatar
Where is grumble when we need him for a question like this?
Quick Reply: Whats the most horsepower you can get from an all motor B18c5?
