| Welcome to Honda-Tech! | ||
#1 |
1993 Honda Del SolMy Garage |
If anybody could find(i could not) a pic of a OBD1 P72 ECU wired for vtec.
I would like a reference picture to help me out. i know where to wire it and what to wire but not really sure how it should look. also pictures of the sensors the wires run to would be great. |
#2 |
Technical Hero
OBD1/2 SOHC/DOHC VTEC SUBHARNESS MINI ME SUBHARNESS 02 EXTENSION HARNESS - www.hondapartshero.net |
#3 |
Holy Shizz! thanks man. By far the best pic/diagram i've seen. this should be a sticky or something.
#4 |
^Hondapartshero
I went to check out your website and found a Honda Acura OBD1 VTEC conversion swap harness. Is this all the wires and everything i need to wire vtec from my ECU to my motor/sensors? |
#5 |
one other thing hondapartshero. if im gonna have an aftermarket intake manifold, do i just not hook up the IAB? or do i need to chip/tune my ECU?
#6 |
IAB COLOR(A17)* isn't that the charcoal/vapor canister?
check out my stuff for sale!! http://hondamarketplace.com/showthre...4#post47292444 CTR WHEELS FT! http://hondamarketplace.com/showthre...7#post47429837 |
#7 | |
Technical Hero
![]() if you are using an aftermarket intake manifold you won't need the IAB wiring and you can just use the OBD1 VTEC subharness I sell, plus its cheaper. It includes all the wiring and connectors needed to basically plug and play. No need to chip the ECU as it won't throw a check engine light for the missing IAB's.
#8 |
Ok thanks hondapartshero. I will be buying that when I get off work today. Thanks for all the help
#9 |
2000 Honda Civic |
awesome diagrams !!!!!! really easy to understand and will help a lot of people!!!!
#10 |
Yeah that is by far the best pic/diagram I've ever seen
#11 |
Best diagram I've seen. Just what I needed. Thanks man!
| Tags |
| 91, a17, board, circuit, civic, color, diagram, ecu, o2, obd, obd1, p72, sensor, vtec, wire, wiring |
