Go Back   Honda-Tech > Honda and Acura Model-Specific Technical Forums > Honda CRX / EF Civic (1988-1991)
Old 04-07-2011, 12:38 AM   #1
///Mathew
///Mathew's Avatar
Default How to replace valve seals?
I've got a b18a1 for my civic that I partially disassembled and now am reassembling, so I bought a top end gasket kit, including head gasket, exhaust, intake etc.
The kit also came with valve seals and I was wondering how easy it is to install them. I don't have any specialty tools nor the experience to remove the valves/springs etc. I was wondering if the valve seals can be replaced without getting in too deep.
Thanks guys.
Integra engine, transmission, front and rear brakes, proportioning valve, master cylinder, brake booster, front knuckles, rear trailing arms, center console, wheels
My Civic is roughly 25% Integra! Build Thread
///Mathew is offline   Reply With Quote
Old 04-07-2011, 03:50 AM   #2
CWBETB
CWBETB's Avatar
Eric Britton
Send a message via AIM to CWBETB
Default Re: How to replace valve seals?
Looking for some answers on this also. Nice build btw
CWBETB is offline   Reply With Quote
Old 04-07-2011, 03:57 AM   #3
Old goat
Old goat's Avatar
http://honda-tech.com/showthread.php...e+seal+removal
Old goat is offline   Reply With Quote
Old 04-07-2011, 07:48 AM   #4
4drEF
4drEF's Avatar
As an alternative for those that don't have shop air or a leakdown tester, you can rotate the crank so that the piston is all the way down and fill the cylinder with nylon rope. When it's full, then turn the crank slowly to compress the rope and keep the valves up. It works, harms nothing, and is a recommended method if you don't have shop air.
All of my posts should be considered for being made into a sticky.
4drEF is offline   Reply With Quote
Old 04-07-2011, 07:58 AM   #5
turtleman321
turtleman321's Avatar
Send a message via AIM to turtleman321
^^^ that's correct. Use it all the time.
One problem he doesn't have specialty tools to remove the valve springs and retainers
turtleman321 is offline   Reply With Quote
Old 04-07-2011, 09:59 AM   #6
CRX Toad
Moderator
CRX Toad's Avatar
And use one of these it makes things so simple. http://www.tooltopia.com/lisle-36050.aspx you will thank yourself. That with either air or nylon rope will make it a snap.
Hondworks
Need a write up on how to fix your CRX cracked climate control, PM me
1990-1993 Accords parting out
1991 CRX HF parting out
PM me for any parts
EG Sedan Tail Lights $60 shipped
CRX Toad is offline   Reply With Quote
Old 04-07-2011, 10:38 AM   #7
4drEF
4drEF's Avatar
Also, you need a set of bent feeler gauges rather than straight ones to set the valve lash.
Good time to put in a new cam as well
15, 2000, 2001, 50, 90, change, civc, civic, crx, honda, replace, s2000, seals, vale, valve, valves
