Old 04-05-2011, 07:46 PM   #1
f22vtec1
Default 93 civic 1.5 NO SPARK NO FUEL
my buddy has a 93 civic 1.5 liter he has no spark & no fuel it just cranks he tried a new main relay a new working ecu all fuses are good
there is power to the dizzy but no spark and the fuel pump doesnt kick on at all
also he said when he jumps it for codes it just stays solid?
i had him also check all grounds he says it all seems fine & clean
any other ideas ? thanks
f22vtec1 is offline   Reply With Quote
Old 04-05-2011, 07:50 PM   #2
mavvrik
mavvrik's Avatar
Zachary Grimm
Default Re: 93 civic 1.5 NO SPARK NO FUEL
Replace the fuel pump and dizzy than
I dont abuse my car i DRIVE my car. If it breaks it doesnt mean i was driving to aggressive....it means i didnt build it strong enough
mavvrik is offline   Reply With Quote
Old 04-05-2011, 07:55 PM   #3
RonJ@HT
Raising the bar
2000 Honda Civic
My Garage
RonJ@HT's Avatar
Triple check these two items:
1) Hood fuse 31 and dash fuse 24. One may be blown. Test for voltage to body ground at both top test tabs of the installed fuses.
2) Clean and tighten the G101 ground wire attached to the thermostat housing.
Don't guess, troubleshoot.
Old 04-05-2011, 08:07 PM   #4
f22vtec1
i just told him to check those he says he did but i told him to use a test light and make sure he checks those 2
he removed & cleaned that thermostat ground tho
Old 04-05-2011, 08:10 PM   #5
RonJ@HT
Raising the bar
2000 Honda Civic
My Garage
RonJ@HT's Avatar
There are fuse box diagrams in the FAQs sticky that will help him locate both fuses. Many people can't find fuse 24 because it's set off from the others.
Old 04-05-2011, 08:17 PM   #6
f22vtec1
does it matter if ignition is on or off to test em? i'll just tell him test every single one with a test light
Old 04-05-2011, 08:20 PM   #7
f22vtec1
also someone said to him his ignition switch could be causing this?
Old 04-05-2011, 08:27 PM   #8
f22vtec1
he said he tested everything w ignition on and all fuses are good
Old 04-05-2011, 08:35 PM   #9
RonJ@HT
Raising the bar
2000 Honda Civic
My Garage
RonJ@HT's Avatar
Does he know where fuse 31 and 24 are? Those are the specific ones he must test. Fuse 31 can be tested with the key off, but fuse 24 must be tested with the key in ON(II). There's no reason to consider anything else until it is absolutely clear that both of those fuses are good.
If the ignition switch were bad, the dash warning lights like the CEL would not turn on when the key is in ON(II).
Old 04-05-2011, 08:38 PM   #10
f22vtec1
ok well he says he tested them w ign on and they test fine ? whats next
Old 04-05-2011, 08:59 PM   #11
RonJ@HT
Raising the bar
2000 Honda Civic
My Garage
RonJ@HT's Avatar
Unplug the main relay and check whether voltage from those two fuses reaches terminals 1 and 5 of the main relay connector.
If he uses a jumper wire to short terminal 1 or 5 to terminal 7, does the fuel pump run?
Old 04-05-2011, 09:07 PM   #12
f22vtec1
k i'll give him the info !
Old 04-05-2011, 09:08 PM   #13
f22vtec1
just so im 1 step ahead if it does run then what? and if it doesnt ?
Old 04-05-2011, 09:09 PM   #14
JdmCoupe91
1997 Honda Civic
Have him test the dizzy if he has no spark... Might be just the rotor or ignitor... Check the cap as well...
As for the fuel, I'm stumped hahah.
JdmCoupe91 is offline   Reply With Quote
Old 04-05-2011, 09:21 PM   #15
Swifty92
Swifty92's Avatar
Send a message via AIM to Swifty92
check and make sure you here the three clicks of the main relay.
also listen for the fuel pump prime in the back seat when you turn the key.
as for no spark test the ignition coil and Ignition Module. Your Better Off taking it to autozone They can test them there Good Luck
92 Suzuki Swift GTi Gone
93 Honda Civic Dx Lsvtec Gone
06 MM Acura Rsx Type S Daily Driven
Swifty92 is offline   Reply With Quote
Old 04-05-2011, 09:21 PM   #16
RonJ@HT
Raising the bar
2000 Honda Civic
My Garage
RonJ@HT's Avatar
One problem likely explains the lack of fuel and spark.
Old 04-05-2011, 09:23 PM   #17
f22vtec1
if the tests on the relay check out
and if pump primes or not when he jumps those terminals on relay ? then what
Old 04-05-2011, 09:23 PM   #18
RonJ@HT
Raising the bar
2000 Honda Civic
My Garage
RonJ@HT's Avatar
There's more possibilities than I want to consider at this early point. Post the results of all the tests I suggested and we'll go from there.
Old 04-05-2011, 09:27 PM   #19
Swifty92
Swifty92's Avatar
less if, more do please
Old 04-05-2011, 09:30 PM   #20
f22vtec1
ok i'll keep u posted :-) thanks guys
Old 04-05-2011, 09:33 PM   #21
greenhatchyy
help this guy lol
greenhatchyy is offline   Reply With Quote
Old 04-05-2011, 09:34 PM   #22
Swifty92
Swifty92's Avatar
do work son good luck brah
Old 04-05-2011, 10:15 PM   #23
f22vtec1
he jumped them and the fuel pump turned on !
Old 04-05-2011, 10:24 PM   #24
f22vtec1
he jumped 1 n 7 on main relay and the pump primed ?
Old 04-05-2011, 10:28 PM   #25
RonJ@HT
Raising the bar
2000 Honda Civic
My Garage
RonJ@HT's Avatar
What about 5 and 7?
91, 92, 93, civic, fuel, geting, honda, hondatech, housing, main, power, pump, relay, spark, thermostat
