Go Back   Honda-Tech > Honda and Acura Model-Specific Technical Forums > Honda Prelude
Old 04-05-2011, 07:29 PM   #1
carloc98
1998 Honda Prelude
Default prelude engine swap
i got a 98 prelude and i wanted to put a new motor in and i was wondering which engine out of the F22, K20, B16, h22 would be the best and if i would have any problems with putting them in
carloc98 is offline   Reply With Quote
Old 04-06-2011, 05:46 AM   #2
carnot
carnot's Avatar
Default Re: prelude engine swap
What is wrong with the motor you currently have? If it is blown the best option would be to rebuild it or swap in another H22. I wouldn't recommend swapping any of the other engines you listed into a 98 prelude. What are your goals with this car? The search feature is your best friend if you are new to this area.
carnot is offline   Reply With Quote
Old 04-06-2011, 10:07 AM   #3
jarol220
1992 Honda Prelude
Agreed do some research before you do anything drastic. for example I wanted high revs so I went F20b, I redline at 8400.
jarol220 is offline   Reply With Quote
Old 04-06-2011, 12:41 PM   #4
Contender_h22a
1994 Honda Prelude
Contender_h22a's Avatar
Send a message via MSN to Contender_h22a Send a message via Yahoo to Contender_h22a
From a prelude owner, how did you get a b16 from all of this?
If your motor blew, you can use any f-series, h-series, k-series, or J-series. As long as you have the money, anything is possible. Well if you want to just slapped it on with nothing to change, get yourself another h22.
Contender_h22a is offline   Reply With Quote
Old 04-07-2011, 05:16 AM   #5
carloc98
1998 Honda Prelude
my motor has over 150,000 miles on it and if i rebuild it i will spend just as much as buying a new one and i cant replace everything so it wouldnt be as good as a newer motor or one with less miles on it and i just would like the best motor overall that i could get ,the b16 in my opoinin is the best motor out there that honda made but there hard to find thats where i got that from.
Old 04-07-2011, 05:48 AM   #6
Hawkze_2.3
Hawkze_2.3's Avatar
'95 Prelude--intake, windshield washer lights, rear body kit, carbon fiber windows. '86 Mazda RX7--Chevy & Borg-Warner powered. '99 Honda CRV--Jurassic Park tour vehicle. '98 Chevy Lumina--what is that thing?
Hawkze_2.3 is offline   Reply With Quote
Old 04-07-2011, 08:36 AM   #7
typemismatch
Honda owns me
typemismatch's Avatar
Can I quote this? B16 into a '98 ... good humor ... sorry ...
Start here, look at the motors that came in the '98: http://en.wikipedia.org/wiki/Honda_P...2.80.932001.29
I just have a couple questions:
First: What's wrong with 150K on a Honda motor? Why do you think you need a rebuild? There are plenty of Honda motors still running around with 200-300K from the early 90's.
Second: Do you know what motor is in YOUR car?
Third: why would you want to put a smaller motor [B16] into any car?
To be helpful though, what you are going to want for a Prelude swap is one of the following: H23, H22A, F20B, or K20. Which one you want is going to based on why you're doing the swap. If you just want a B16 cause its "baawller!!", rethink your swap, do research on what fits right in. I've provided the basics below.
The H and F blocks are "generally" drop ins, pull yours, drop the new one in. The worst you should have to do is add/lengthen a couple wires, maybe match up motor mounts using mounts from another H or F block, I've seen weirdness with the F22 tranny mount into an H23 4th gen.
The K blocks require at the minimum changing the motor mounts, finding the right axles, fixing up the OBD2+ wiring to your car, possibly changing the wheel spindles/hubs and suspension to match up with the axles. I'm not sure of the specifics with the K, I just know its been done.
Hope that clears a couple things up.
1992 Prelude S - 469hp/340tq@15psi - 12.46@117mph
2007 Civic Si - FG2 - almost stock (DD)
92 EG H2B - build thread http://www.honda-tech.com/showthread.php?t=2944704
typemismatch is offline   Reply With Quote
Old 04-07-2011, 11:30 PM   #8
BlackCatt
BlackCatt's Avatar
b16 in a prelude, no way man forget about it.
BLACKCATT
BB2_H23A1
BlackCatt is offline   Reply With Quote
Old 04-08-2011, 07:31 AM   #9
minilogoguy18
^It would be the slowest Prelude ever.
93 BB2 - JDM H22a/T2W4 Euro R transmission
Originally Posted by PirateMcFred View Post
Everyone's ****'s broken and they can't find a Helm Manual to read.
minilogoguy18 is offline   Reply With Quote
Old 03-01-2014, 07:21 PM   #10
newhonda23
i have a 1992 Honda prelude i was thinking of swapping my h23 for a h22 i plain on putting a turbo on my prelude i don't know what engine is going to give me more power an can handle better and should i put a 6 speed transmission or keep the 5 speed transmission
newhonda23 is offline   Reply With Quote
Old 03-03-2014, 08:35 PM   #11
1funryd
1funryd's Avatar
The fact that you asked what motor is better for turbo charging tells everyone that you need to do research.
If you do not understand what a turbo charged motor consists of, then you should not attempt it until you have done the proper research and talked to the local tuners in your area who will help you keep your motor alive.
It does not matter what motor you use, adding a turbo changes everything.
So google turbo's and their purpose and then google, how to turbo charge any motor, then separately google turbo requirments for turbo charging H series motors.
Then you will know what you will need. And by the way, the google searches will more than likely send you back to thread that have been posted here on Honda-tech or preludepower.com.
Project Manager for the new Aftermarket for the 3rd gen Prelude(88-91) www.1funryd.com
Email: 1funryd@comcast.net
Ksport & Cometic Dealer.
1funryd is offline   Reply With Quote
Old 03-05-2014, 08:03 AM   #12
Z99doc
Im currently putting a H23 in my 92 prelude. Ill let you know how it turns out.
Z99doc is offline   Reply With Quote
Old 03-11-2014, 05:21 AM   #13
Shake79
if its cheaper to rebuild definitely do that, or swap w/an h22. Personally, just rebuild it if you can.
Shake79 is offline   Reply With Quote
22, 93, 98, acura, block, diy, engine, faster, k20, motor, prelude, rdx, swap, swapping, swaps
Similar Threads
Headers for a JDM f22b DOHC ????? 93 prelude si?? ronqqq Honda Prelude 4 03-10-2014 09:45 PM
F22A4 in a 1994 prelude? Nytrious Honda Prelude 1 09-14-2013 03:37 PM
help yunyoPR Honda Prelude 2 08-03-2013 04:55 PM
JDM H22A swap into 98-02 Accord - Which Header (92-96 Prelude or 97-01 Prelude)? Mike95lude Honda Accord (1990 - 2002) 0 04-24-2013 07:43 AM
I need help with my prelude zvbiv Honda Prelude 1 10-10-2012 05:04 PM
