Old 04-05-2011, 10:19 AM   #1
campfire
1994 Honda Accord
Default whats signs of a bad head gasket?
I got a 94 Honda accord lx I found oil in plugs I was told it could be seals or a blow head gasket so I don't want to doo all that work for a gasket thats fine. the car dont smoke radiator fuild is fine never goes down, oil don't burn away so I thinking its just plug seals if that's so when I pull to valve cap off and I pull The rocker ARM off will that mess with the valves?
1994 Honda accord lx
campfire is offline   Reply With Quote
Old 04-05-2011, 10:42 AM   #2
bshaw
bshaw's Avatar
Default Re: whats signs of a bad head gasket?
1. oil dip stick will have white cream on the end of it
2. oil can be spotted in the antifreeze
3. white smoke out the exhaust
4. white powder on the spark plugs
bshaw is offline   Reply With Quote
Old 04-05-2011, 10:46 AM   #3
campfire
1994 Honda Accord
Don't have any of that so just be the plug seals now bout the rocker ARM if I pull it off will my valves still be fine or would I have to adjust them?
Old 04-05-2011, 01:48 PM   #4
mavvrik
mavvrik's Avatar
Zachary Grimm
Start with your valve cover gasket. If the oil is still there its most likely the valve seals on the under side of the rocker arm assembly. Those motors are notorious for bad seals. Its very easy to change them and no you will will not have to re adjust the valves. Just make sure you put the assembly back on carefully and correctly cause if you dont you will bend the valves
I dont abuse my car i DRIVE my car. If it breaks it doesnt mean i was driving to aggressive....it means i didnt build it strong enough
mavvrik is offline   Reply With Quote
Old 04-05-2011, 04:39 PM   #5
poorman212
If you have never done this before. I'd suggest you back off the adjusters before removing the rocker assy. Then after installing the rocker assy adjust the lash.
66 Chevelle...89 LX auto...89 LXI 5 Speed
...95 EX auto...07 Pilot 2wd
87 LX 5 Spd (sold )...88 LXI Auto (soon to be sold)
poorman212 is offline   Reply With Quote
Old 04-05-2011, 06:06 PM   #6
mavvrik
mavvrik's Avatar
Zachary Grimm
As long as you have feeler gauges you can do that
1994, accord, acoord, bad, blown, cover, gasket, gaskets, head, honda, motor, sign, signs, symptoms, valve
