JDM Integra Type R Exhaust Diameter
Old 04-04-2011, 12:36 AM
b18c_dc2_davis's Avatar
Default JDM Integra Type R Exhaust Diameter
I know this has been covered many times...
What key words do I need to use for the search!?!?
but no matter what I look up, I come up empty handed.
Sorry, just venting.
Anyways, this will be answered easily.
What is the diameter of the JDM ITR B-pipe? 2.25" or 2.5"? 60mm or 57.2mm?
Any reply will help.
Thanks,
Old 04-04-2011, 12:38 AM
TypeRMOBBiN209's Avatar
Default Re: JDM Integra Type R Exhaust Diameter
i think its 2 3/8
Old 04-04-2011, 01:16 PM
Originally Posted by TypeRMOBBiN209
i think its 2 3/8
Thanks,
So the aftermarket exhausts should have the bigger diameter than the stock jdm.
Old 04-04-2011, 03:21 PM
B serious's Avatar
not nessecarily. Apex'i World Sports and N1s are like 2 3/8''. I'm pretty confident that the USDM exhaust is 2.38''...so..would the JDM one be larger? Or is the U.S. one not 2.38?
Old 04-04-2011, 03:37 PM
Just did a quick research
Stock Integra Type R 2.25 57.2
Stock Integra Type R (JDM) 2.25 (ID) 57.2
The USDM and the JDM one have the same diameter.
Old 04-06-2011, 02:05 PM
I said I don't want a title!
Todd00's Avatar
Yes, JDM and USDM exhausts are the same size. The only difference being the different b-pipe length.
After the bottlenecks are removed, the exhaust is plenty adequate in size unless you're making a lot more HP.
Old 04-06-2011, 02:35 PM
Accident Prone
Just a n00b's Avatar
Bottlenecks being cat, right?
Old 04-06-2011, 02:41 PM
Todd00's Avatar
Not exactly. The OEM B-pipe and muffler necks down the piping a bit. If you have one off and look at it, you'll see what I mean.
Old 04-06-2011, 02:49 PM
Accident Prone
Is there anyone that makes something similar to the OEM b-pipe in shape but with a wider diameter?
Old 04-06-2011, 03:53 PM
Todd00's Avatar
I think there used to be one or two, but not sure if they are still available.
The OEM B-pipe bottleneck is easy to take care of though. A muffler shop did it for me for about $30.
Personally, I'd like to find a good quality axle-back again. I had a SS Comptech back in the day, but I stupidly sold it.
Old 10-07-2011, 08:39 PM
b18c5 power's Avatar
Jdm itr is 2.25 (Od) not (Id) i just went through this with Dave at smsp !
Usdm its even smaller sorry!
Old 10-08-2011, 06:41 AM
jahraul's Avatar
I am also interested in this info..
I want to do a JDM ITR header, and OEM USDM ITR Muffler. What do I need to fill in between the header and muffler?
is the JDM b pipe the same diameter as the USDM b pipe?
the parts listed above may go on my 99 GS-R coupe.
BTW: I will be selling my Comptech muffler and Comptech B pipe soon if anyone is interested.
TIA!!
Old 10-08-2011, 07:32 PM
Todd00's Avatar
TIA!!
What's it matter? The muffler will be the bottleneck anyways. JDM vs. USDM B-pipe will be of little consequence.
And double whammy on putting a forsale post inside of a GSR question.
Old 10-08-2011, 07:37 PM
jahraul's Avatar
I got the muffler will bottle neck anyway. I dont understand what youre saying about the B pipe.
I said it will be for sale soon. No thread, pics, or even price are up man.
Old 10-08-2011, 07:43 PM
Todd00's Avatar
If you are wondering about B-pipe length, this question has been answered 100's of times over (GSR or not).
P.S. It all depends upon cat length.
Old 10-08-2011, 10:50 PM
01-0720's Avatar
usdm and jdm b pipe are the same length, the cats are different lengths, to accommodate the 98 spec jdm itr exhaust manifold
the bottle neck in question on the b pipe is right before where the b pipe connects to the muffler
people always argue the size of the piping between usdm and jdm, but even if there is a difference in size it will never make a difference in power, because if you are using a stock jdm itr exhaust mani, cat, b pipe and muffler your motor is also pretty stock, so this exhaust will not hold you back at all in any way
Old 10-09-2011, 07:30 PM
jahraul's Avatar
sweet, so if I do a JDM ITR header, USDM ITR b pipe, USDM ITR muffler, what cat size & brand do you recommend to complete the setup?
Old 10-09-2011, 07:40 PM
01-0720's Avatar
you will need a jdm length car, if that is all your doing id recommend a oem jdm itr cat
artin01
09-18-2021 05:16 PM
spoonskywalker
03-27-2011 05:25 AM
MartyMarGSR
12-02-2002 09:13 PM
houston
03-06-2002 04:28 AM
Quick Reply: JDM Integra Type R Exhaust Diameter
