Old 04-02-2011, 08:01 PM   #1
portugueboy10
1998 Acura Integra
My Garage
portugueboy10's Avatar
Icon3 How to change auto transmisson fluid on 94 accord ex
i was wondering if anyone knew how to remove the bolt to drain the auto transmisson and where its located???
portugueboy10 is offline   Reply With Quote
Old 04-02-2011, 08:19 PM   #2
sony224422
sony224422's Avatar
Default Re: How to change auto transmisson fluid on 94 accord ex
its not hard to do.. theres a inverted hex head bolt on the bottom of the trans on the passenger side. put your ratchet in it and take it out.. drain the fluid. you'll get about 1/3 of the fluid out. you can either drive around and do it 3 times in total or get it flushed or just do 1/3 and have fresh fluid at least. There is no filter that is serviceable externally, and refill through the dipstick
96 accord lx- converted into 5spd ex http://is.rely.net/1-92-29998-l-1gbM...AmVuBW3hGg.gif
93 civic CX (project car)- Sold
1997 dodge ram 1500 sport 4x4 extended cab
360 magnum
sony224422 is offline   Reply With Quote
Old 04-02-2011, 08:32 PM   #3
portugueboy10
1998 Acura Integra
My Garage
what is the rachet size that will fit the bolt?
Old 04-02-2011, 10:08 PM   #4
mavvrik
mavvrik's Avatar
Zachary Grimm
I thought you could also just drain the tranny pan all together and replace the filter
I dont abuse my car i DRIVE my car. If it breaks it doesnt mean i was driving to aggressive....it means i didnt build it strong enough
mavvrik is offline   Reply With Quote
Old 04-02-2011, 11:22 PM   #5
MAD_MIKE
MAD_MIKE's Avatar
I'm pretty sure its 3/8" ratchet. The bolt accepts the ratchet directly, no sockets. Plug in and wrench away, don't forget to get a new crush washer before you start.
Nope. There isn't a removable transmission pan. There is a drain plug, and the filter is a small screen buried inside the transmission attached to the valve body, which is located between the gear set and torque converter. No way or need to clean it.
Remember, Honda ATs are more like MTs, rather than a clutch and shift forks, there is a torque converter and clutch packs. No planetary gearset voodoo in these transmissions.
MAD_MIKE is offline   Reply With Quote
Old 04-03-2011, 06:23 AM   #6
portugueboy10
1998 Acura Integra
My Garage
how many quarts does the transmisson take??
Old 04-03-2011, 10:26 AM   #7
sony224422
sony224422's Avatar
if you do it that way, i believe 3 or 3.5 qts come out. get 4 to be safe
360 magnum
Old 04-03-2011, 03:53 PM   #8
portugueboy10
1998 Acura Integra
My Garage
i cant get the bolt loose, even tried wb-40
Old 04-03-2011, 04:00 PM   #9
redbull-1
redbull-1's Avatar
First make sure the ratchet is seated all the way in the drain bolt, to make sure tap the ratchet lightly into bolt. Now, with both hands, use a pulling motion on the ratchet handle.
Good luck.
redbull-1 is offline   Reply With Quote
Old 04-03-2011, 05:21 PM   #10
mavvrik
mavvrik's Avatar
Zachary Grimm
get more leverage on the bolt.
Old 04-03-2011, 09:49 PM   #11
The_Todd
Farts in the shower
The_Todd's Avatar
Slide a breaker bar over your ratchet to get more torque on it.
-Ken
-07 CBR600RR
-96 Dodge Ram 2500 Cummins
The_Todd is offline   Reply With Quote
Old 04-04-2011, 08:39 AM   #12
19Accord97
19Accord97's Avatar
I just use an old piece of pipe. btw, id use a crappy ratchet in case it breaks.
19Accord97 is offline   Reply With Quote
Old 04-04-2011, 01:40 PM   #13
nicolaselias
nicolaselias's Avatar
I'd also try some liquid wrench before you do it instead of just wd-40...
There is a little trick we do with our cars when changing the trans fluid..
1. Look up total capacity
2. Drain from the trans pan, but collect into a used oil galon jug or tie jug...anything that can tell you how much you drained..
3. Fill back up the same amount of fluid lost
3. There will be fluid left in the torque converter that you didnt get to, to get this all out you can either run the car for a bit again and drain as before,
OR
Disconnect the ATF cooler hose from the radiator.. Connect some tubing or hose to it and run the other end to a collection bottle..
Start the car and drain about 2 qt's.. Top up, and do this about 3 or 4 times.. When you are done you should be very close to 100% new fluid
PS. You can do this way from the start if you truly can't get the drain bolt out
Finally, use Honda ATF, these trannys can be sort of picky sometimes..
96 JDM Accord EX F20B2 (Located in Caribbean)
02 Volvo S80 2.9 (Tampa, FL)
nicolaselias is offline   Reply With Quote
1994, 2008, 93, 94, accord, bolt, capacity, civic, drain, fluid, honda, ltr, plug, size, trans, transmission, transmissonfluid
