Old 04-01-2011, 05:34 PM   #1
preludebro
Default Mothers 96 Accord, front end roaring, increase with speed
The front end of my moms car makes a roaring noise in the front end at higher speed rates. It sounds like the tires are making the roaring noise, but those aren't whats doing it. Shes afraid it's her tranny, but the tranny seems fine. It's smooth, shifts smooth, shifts correctly on time, no fluid leaks. I believe her wheel bearings are bad. Does this sound like a legit problem?
preludebro is offline   Reply With Quote
Old 04-01-2011, 05:37 PM   #2
phootbag
phootbag's Avatar
Default Re: Mothers 96 Accord, front end roaring, increase with speed
Sure. Does the noise change as you CAREFULLY swerve left and right while driving? This loads the bearings and can help pinpoint which bearing is bad.
phootbag is offline   Reply With Quote
Old 04-01-2011, 05:44 PM   #3
preludebro
Hmm. If I can recall, I do believe it quiets down when she turns or something. I'm not positive, but I'll have her try this and see what happens. Thanks.
Old 04-01-2011, 06:02 PM   #4
singlecamsaint
singlecamsaint's Avatar
mine hasa similar problem it does it turning right, i changed the driver side bearing and its still doing it. the passensenger side bearing had 0 play in it
singlecamsaint is offline   Reply With Quote
Old 04-01-2011, 06:06 PM   #5
phootbag
phootbag's Avatar
Wheel bearings can be tricky. Since they are a double-race bearing the right bearing can make noise when turning left and vice versa.
The RIGHT way to diagnose this is to raise the vehicle completely off the ground, a shop lift is ideal, and run the car in drive. Increase the wheel speed until you can hear the noisy bearing with a stethescope.
Careful you dont' kill yourself while doing this test.
Old 04-01-2011, 06:10 PM   #6
preludebro
Yeah. It sounds like it's the driver side bearing. Stethescope... such a simple idea. lol. Thanks. Good thing theres a shop I can use with a lift. Singlecamsaint, is that your axle?
Old 04-01-2011, 07:14 PM   #7
singlecamsaint
thats what im thinking or the intermediate shaft i just bought the car so i dont have much of a history... i was goning to just replace the driver side axle and intermeidiate shaft and see what happens
Old 04-04-2011, 05:06 PM   #8
95halx
If the noise is still there or gets louder when turning right its the left front bearing and if gets louder when turning left its the right front bearing. hope this helps. Had it happen with mine but I just replaced them both. Noise gone
95halx is offline   Reply With Quote
Old 04-04-2011, 05:13 PM   #9
phootbag
phootbag's Avatar
Bearings usually make noise because the races get rough spots. You may not be able to measure any "play" in a noisy wheel bearing.
Old 04-05-2011, 03:15 AM   #10
singlecamsaint
it wasnt my bearings after all, after raising the car on jackstands and running it to 40 mph i had a helper cut the wheel, the passenger side axle started shaking violently, this is the one ill be replacing. OP if you cant find the problem try doing this it helped me tremendously
Old 04-05-2011, 01:59 PM   #11
phootbag
phootbag's Avatar
Awsome! A bit of diag saves LOTS of money.
Originally Posted by phootbag View Post
A "dizzy" is that magical thing you replace when your car wont start.
Originally Posted by chrisff521 View Post
Ok so youre saying I should replace the whole "dizzy" ?
1996, 96, accord, bearings, clip, drivers, end, front, honda, increases, loud, noise, roaring, side, speed, vibration
