Car not starting. Clutch switch or starter? Help
Old 03-31-2011, 09:08 PM
zerovandez's Avatar
Default Car not starting. Clutch switch or starter? Help
1997 Civic Hatch with B18C GSR engine. Runs fine and is BAR'd in Socal. Something strange has been happening recently, but not often. The car doesnt start all of the time. I press the clutch, turn the key, then nothing. I don't even hear the starter cranking. Everything else seems to go like the humming of the fuel pump, dash lights, and stereo. Doesn't seem like an electrical problem. I'm thinking a bad clutch switch, or starter. What do you think?
Old 03-31-2011, 09:09 PM
Former User's Avatar
Default Re: Car not starting. Clutch switch or starter? Help
Start by check whether the rubber stopper that presses on the switch is damaged.
Old 03-31-2011, 10:19 PM
mooze's Avatar
had this issue to...it eventaully just stopped all together..i just bypassed the clutch switch
Old 04-01-2011, 05:42 AM
zerovandez's Avatar
Thanks guys. I'll have a look this weekend. Is there a reason for 2 clutch switches? To bypass, just jump the 2 wires leading to the switch, right?
Old 04-01-2011, 05:47 AM
The upper switch is for the starter and the lower one is for cruise control.
Don't permanently jump the starter switch connector. It's unsafe. Start by checking the rubber stopper and whether it is adjusted properly for the pedal height.
When you turn the key to ON(III) to start the engine and it doesn't crank, do you still hear the starter solenoid click? If so, your starter may be on the way out.
Old 04-01-2011, 12:43 PM
zerovandez's Avatar
No. I don't hear the starter solenoid click. Completely silent with the excpetion of the fuel pump. I guess I wouldn't have to worry about the CC switch. The ECU is putting out P1456 and P1457. I wouldn't think this would have to do with anything I'm experiencing, right?
Old 04-01-2011, 01:05 PM
CAVTECSol's Avatar
It could be your coil. I had mine go out around 120k and it had the same symptoms you're seeing.
Nikki Aulicino
01-26-2017 10:25 PM
dannycraq
24
09-20-2014 05:07 PM
magicmyst98
14
09-02-2013 12:06 PM
KimvdLinde
06-29-2013 12:19 PM
viera
09-18-2011 08:02 PM
Quick Reply: Car not starting. Clutch switch or starter? Help
