Wiring Vtec to a Non Vtec 92 si prelude
Old 03-28-2011, 12:43 AM
ellywyte's Avatar
Default Wiring Vtec to a Non Vtec 92 si prelude
I have a 92 honda prelude si non vtec and i swap with a 2.2 blue top dohc h22a vtec engine.
my car runs well with the p14 ecu that was original ecu there but the vtec wont work.
I was told to get a vtec computer from the prelude vtec which is the p13 ecu 0bd1
When i plug it up the vtec still wont come in
I was told i have to do some extra wiring to the vtec solenoid,knock sensor etc
Question: What type of electrical wire should i buy or where can i get the right wires to wire the vtec ?
This is the instuction i was giving on how to wire it
Old 03-28-2011, 05:30 AM
1GPlusSH's Avatar
Default Re: Wiring Vtec to a Non Vtec 92 si prelude
I would guess 12 or 14 gauge wire
http://www.collectiveracing.net/cgi-...=ST;f=11;t=107
i couldn't get anywhere on this site because it's blocked here. that's the site in the FAQ section on here...good luck
Old 03-28-2011, 08:37 AM
ellywyte's Avatar
thanks bro
Im actually a rookie to anything that has to do with electrical
Do you think it would make a difference if i get a automatic P13 or manual P13 for a 5 speed manual transmission.
Would there be a difference in the way it runs?
Old 03-28-2011, 09:40 AM
1GPlusSH's Avatar
whichever is cheaper...there is a writeup someone on how to convert one to the other. i'll look through the FAQs...you should for issues, too.
Old 03-28-2011, 09:44 AM
1GPlusSH's Avatar
well, it was for a 5th gen...
https://honda-tech.com/forums/honda-prelude-4/official-auto-manual-ecu-conversion-thread-1275452/
maybe you can find something in there to help you. you may have to look around for a p13 writeup, if there is one.
Old 03-30-2011, 10:42 AM
PremiumPrelude's Avatar
Stick with the manual p13...
Old 03-30-2011, 02:28 PM
ellywyte's Avatar
well i dont have a manual p13 i got this i got an auto for 60 bucks so i took the offer seen that they usually cost 250
I have another issue my selenoid dont have an oil pressure switch to connect to
Do you think i need an oil pressure switch for the selenoid?
sameerb1
02-22-2011 08:33 PM
jetoutant
11
01-02-2008 07:50 PM
bluedxhatch
05-02-2005 06:34 PM
93PGTZE
08-22-2002 07:02 AM
Quick Reply: Wiring Vtec to a Non Vtec 92 si prelude
